brakes got the shakes
Re: brakes got the shakes
Originally posted by 2k2 TLS
does anyone notice that their cars steering wheel kinda shakes when you brake hard going at freeway speeds? at slow speeds (under 65 mph) it doesnt shake.
I agree with Bioyuki, sounds like you have a warped rotor. Dealer will fix.....or better yet, this give you a reason to buy some cross drilled rotors from this site.
There an upgrade from O.E.M. and their lighter too
Its what your brake pads grab to slow down your car, and they will warp for instance if they get too hot in any one area, (i.e. braking hard to come to a stop and then sitting at a light with your brakes on will hold the heat in that one area longer). Ours seem to have some unusually predisposition to warp easier than they should.
Your brakes basically consist of a rotor (which is a "disk"), rotating with your wheels, and "calipers" or brake pads to slow the rotation. When you apply the brakes, frictional pads that oppose each other press up against each side of the disk, slowing the rotation of the disk. When the disk becomes warped you can feel the undulations as the brake pads follow the in-out motion to match the surface of the disk. I've had cars with disks brakes that would warp if you look at them funny. It's very annoying, kind of like a chattering clutch.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
...Shyne
