Brake Trouble? Brake and Shake?!?
Has anyone else experienced this? I used the search function but nothing came up.
My brakes feel like they're getting worn out. I have 11,000 miles on the car, change my oil regularly, generally take good care of the car, yet I find when I decelerate, for instance when driving on Rt. 9 in Jersey (essentially a highway with traffic lights) my car starts to shake when I brake.
Anyone else experience this? What is it indicative of?
Re: Brake Trouble? Brake and Shake?!?
axleback
Originally posted by osofastferu
your rotors probably warped in the rain or when you hit a puddle of water.
Is there a visual way to tell if your rotors are warped? When your rotors are warped what does that mean? That the rotors aren't even across the entire diameter of the rotors. I feel my vibrations in my steering wheel when i brake on the freeway, when i'm going about 60-70 mph...i don't know it'f it's my ABS that cause the vibration or something else, but i don't get the vibration at lower speeds...does this seem like my brakes are warped??
Rotors
Acura has a Service Bulletin out about this. Take it in to the Dealer, they'll fix the rotors and add new brake pads.
I just bought a new Front set of KVRs from TIM. Cross-Drilled and Cadmium Plated. They look very nice. Wt = 18 lbs. If your interested in Brembo Rotors - hopefully I will be getting the rears tomorrow or tuesday, you can check out the "GROUPBUY" over at THE CL-S Forum.
lanechanger
Oct 13, 2015 10:56 AM
