"Brake Lamp" light on?
a bulb. Pull each one out and double check.
they sell our special 3 dollar bulbs in a convenient $6 2 pack because whichever one is out- the opposite side will die soon
I bought 2 packs and replaced them all to be done with it
Did you check the 3 rd brake light- in the rear window- you access the bulbs from inside the trunk
Maybe its a vac leak
03 ABP tls
i replaced all mine cuz i had the light too. and now its just weird, sometimes the barke lamp light goes on, sometimes it dosnt. and when it is on, seems like everything is lit. oh well.
possible early warning of brake light switch failure? just guessing
or bad ground wire connection that gets jostled
there has to be a filament in one of the bulbs tot working correctly causing the light. For teh price id just start replacing bulbs till it goes away
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
