Bought a used TL, what should be done to it?
Old Oct 29, 2013 | 06:19 PM
BetterBob's Avatar
So, beyond the obligatory oil change, and maybe sea foam, is there anything model specific i should do?
Thanks!
Old Oct 29, 2013 | 06:24 PM
M224armstrong's Avatar
did u check the transmission fluid and see the color before buying?
Old Oct 29, 2013 | 06:28 PM
BetterBob's Avatar
<_< no. I didn't really put much research into it. Bought it from a friend that drove it daily, so i assumed it was serviceable.
I'll go look now.
Old Oct 29, 2013 | 06:35 PM
BetterBob's Avatar
Its red. Not bright red, but red.
Old Oct 29, 2013 | 06:45 PM
Skirmich's Avatar
^Should change that out ASAP..
I would:
1.- Change Engine Oil + Filter
2.- Change ATF + Screw type Filter
3.- Change Brake Fluid
4.- Change P/S Fluid
5.- Change A/F
6.- Inspect Brake rotors and Pads replace if necessary
^ I always do this on a New car regardless of make and model.
Old Oct 29, 2013 | 06:50 PM
BetterBob's Avatar
Is there a DIY on changing PS fluid? I don't think I've ever done that to any car.
Old Oct 29, 2013 | 06:52 PM
3.2TLc's Avatar
Any 10 year old car with over 100k is going to require attention.
Best place to start is your owner's manual and then download a copy of Acura's factory service manual if you're a DIY'er. Check the 2nd Gen DIY sticky for lot's of common issues and tips for resolving them. It's all here if ya take the time to look for whatever concerns ya.
Old Oct 29, 2013 | 06:59 PM
BetterBob's Avatar
Ah, cool, found it. Thanks.
Old Oct 29, 2013 | 07:01 PM
Skirmich's Avatar
Damn I did a DIY but for a Honda forum..
You will need:
2x ATF (use Z1 or DW-1)
5-6x Honda Genuine P/S Bottles
1x Empty bottle you can cut its inlet
1x Helping Buddy
Its pretty easy just need to:
1.- Locate your P/S Reservoir.
2.- Locate your Return Line (The most upper one in the Res)
3.- Remove the Return Line and fix a bottle to catch the P/S Fluid.
4.- Now use your helping buddy to start the engine for around 3 seconds and shut it off.
5.- Use the ATF and slowly pour it into the reservoir so it can start to circulate as P/S fluid (DONT LET THE PUMP STARVE OF FLUID!)
6.- REPEAT UNTIL YOU USED ALL 2 QUARTS OF ATF
7.- Now open open you first bottle of P/S and flush out the ATF until you see less red liquid and more transparent (P/S Fluid is Transparent / ATF is Cherry Red).
8.- Use only 1 bottle of P/S for flushing out the ATF (Don't worry if it doesn't come out completely Clean its alright to leave some ATF in the System).
9.- Close the Inlet line of the P/S and Fill it up with the remaining P/S Bottles.
ILL SEARCH FOR PICS!
DONE! In a rate of 1-10 for difficulty its around a 1 or 2 at most.
Old Oct 29, 2013 | 07:09 PM
Skirmich's Avatar
This is the Return Line:
Old Oct 29, 2013 | 07:12 PM
BetterBob's Avatar
Thanks again!
But, why the ATF? Just curious.
Old Oct 29, 2013 | 07:14 PM
Skirmich's Avatar
ATF serves as a detergent for the P/S system but it isn't harsh to the seals like MANY P/S only Detergents sold in Autozone and such.
Old Oct 30, 2013 | 06:41 AM
3.2TLc's Avatar
If ya prefer oem, Honda does have a specially formulated PS fluid which is recommended by the manufacturer.
Old Oct 30, 2013 | 07:08 PM
Yikes's Avatar
You will need:
1x Helping Buddy
This post should be added to the DIY section.
Old Oct 30, 2013 | 08:06 PM
Skirmich's Avatar
^ I had pictures to go with the DIY but sadly I lost them in my photobucket account when I did a clean :/ forgot about them and broke the links...
I hope the write DIY is enough..
Old Oct 30, 2013 | 09:47 PM
BetterBob's Avatar
I may be able to supply pictures when I do it. I managed to step on my digital camera, so they would be cell phone pics.
But they should be sufficient to show what's going on.
Also, the manual shows to clear the system of fluid completely, then refill it. But i like your way better.
Old Oct 30, 2013 | 10:38 PM
Yikes's Avatar
I also plan on doing it soon. I would hate to see my rack fail partly because the fluid got so nasty.
Those aren't cheap to fix either, not to mention they're a pain in the ass to get to if you plan on DIYing.
Old Oct 30, 2013 | 10:39 PM
Skirmich's Avatar
^ Yah I would not run the P/S Pump dry like the manual says :S that thing is shit expensive to risk it just for a Fluid Change..
And thanks! I'm glad it helps.
Old Nov 20, 2013 | 05:42 PM
BetterBob's Avatar
I would:
1.- Change Engine Oil + Filter (Check)
2.- Change ATF + Screw type Filter (One of the 3x3,no filter yet)
3.- Change Brake Fluid (Check)
4.- Change P/S Fluid (Not yet, after mandatory)
5.- Change A/F (Totally forgot)
6.- Inspect Brake rotors and Pads replace if necessary(rotors need turned/replaced.. Vibrations under braking.)
I edited the above to show what's done. But do you have a part number/ suggested place to get a screw on trans filter? And possibly a how to? I'm sure i can figure it out, I think i saw it when i swapped the first 3qt.
I need to do it on the last of the 3x3. And I'll do everything else i can on the list... given my bank account allows.
Old Nov 20, 2013 | 06:06 PM
3.2TLc's Avatar
The 2nd Gen "DIY" sticky has the procedure for replacing the spin on ATF filter.
Ya can get the filter at most parts stores if ya don't wanna pay the stealership $.
Old Nov 20, 2013 | 06:13 PM
BetterBob's Avatar
I could have sworn i looked through there today. I'll look again.
Is it in the 2006 tranny replacement thread?
Edit: This will be my 2nd of the 3x3. I'm not sure why i thought i only needed to do it twice.
Old Nov 20, 2013 | 06:23 PM
3.2TLc's Avatar
No, but if ya go to the top of this page's thread...you'll notice 3 Sticky's for the 2nd Gen. The third and last sticky is labeled as Sticky "New" Official 2nd Gen TL DIY Thread ..... within this you'll discover a whealth of valuable info all compiled into one handy area for your DIY pleasure. Enjoy !!!
Old Nov 20, 2013 | 06:31 PM
BetterBob's Avatar
Yes, I understand this. What I am saying is that I am either missing the information that I require, or that it is in a thread that i would not access for such information..
I have just totally read this:
https://acurazine.com/forums/showpos...38&postcount=3
Old Nov 21, 2013 | 06:57 AM
3.2TLc's Avatar
https://acurazine.com/forums/2g-tl-problems-fixes-117/transmission-bypass-spin-filter-replacement-852465/
DIY trans bypass filter replacement
Old Nov 21, 2013 | 07:45 AM
BetterBob's Avatar
Thank you!
Was it in the DIY? I may have been a bit intoxicated last night, and i tend to speed read.
Either way, thanks again.
vpasla1
Sep 17, 2016 07:24 PM
bluetl04
Aug 16, 2016 02:49 PM
dainmezron
Oct 16, 2015 06:56 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
