Blitzsafe problem - Audio through Right Channel only
Dear Acura 3.2 TL'rs:
I just got my HON/AUX DMX V.1 (ordered from Enfig) for my 99 Acura 3.2 TL and installed it for my XM Roady2 - but i am getting audio only through my right channel. I've all stock equipment in my Acura. Can someone help. Had planned to have this complete this labor day weekend.
VIJAY
99 ACURA 3.2 TL
00 MAZDA MPV
VIJAY
99 ACURA 3.2 TL
00 MAZDA MPV
Check the blitzsafe box itself. I initially had the same problem with mine and after confirming the RCA connections I fidled (pushed them in while testing the audio through the head unit) with the wires coming out of the box which fixed the problem. I know this sounds obscure but it fixed the issue.
Blitzsafe Audio problem
I checked and found that when i wiggle / press the white RCA connectors, the sound starts coming - now, the issue is, should i try to fix it or request a replacement. I should be able to buy a female RCA jack and connect to the wire where white is connected on the cable from the blitzsafe box.
Any suggestions?
Any suggestions?
Blitzsafe sent RCA connector to resolve problem
Blitzsafe was really helpful - sent me cables with RCA Connector and I opened up the box and just replaced the bad RCA cables on the HON-AUX-DMX V.1
Go Blitzsafe!!!!
Go Blitzsafe!!!!
RCA Cable from Blitzsafe
Fortunately, for me, the unit came broken - so when i tested it, I still had my central console all ripped apart and lying around in the car.
But after going through (removing the central console), I'll say, it's about 12 ~ 14 screws and about 1/2 hr job - at the most.
cycdaniel
12-17-2019 10:58 AM
sockr1
10-01-2015 01:31 AM
ivegotthenav
09-11-2015 07:51 PM
