Ballasts
Old Dec 23, 2010 | 03:45 AM
ABClaypool's Avatar
Ballasts
Will the ballast that is used in an 06-08 TL work with my 02 TL-S? One of my ballasts is dead and the other is on the way out as the bulb flickers when i take turns. And in case anyone asks, yes i did move parts around to figure out the culprit.
Old Dec 23, 2010 | 11:48 AM
01tl4tl's Avatar
try an auto recycle yard/junkyard
they know interchange on years and parts and may have a set
or
get aftermarket waterproof units for less, but have to make a few slices
good luck!
Old Dec 23, 2010 | 11:52 AM
gold2003tl (90)'s Avatar
2003 TL-p
get aftermarket waterproof ballast and mount it on the outside. drill a hole to run the wire inside to the bulbs and seal it up real good with silicon. what i did and good for almost 2 years now.
Old Dec 23, 2010 | 12:32 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
My plan for the future is to just leave the old ballast in there, so it keeps the seal, and stick a ballast on the outside...
Old Dec 23, 2010 | 12:48 PM
2003 TL-p
thats what i did, i was able to zip tie the new ballast right on top of the old ballast on the outside. its a great quick and easy fix. a lot of us az'er will be doing this since there has been an increase in ballast failures mainly due to age.
CL-S progression 01
Jan 26, 2016 04:15 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
h22lude
Sep 27, 2015 06:22 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
Juandiablo
Sep 27, 2015 10:32 AM
