back seat removal
Old Apr 2, 2004 | 08:17 PM
goldendragon576's Avatar
TL-S driver
Question back seat removal
How do you remove the back seat? I want to stiffen my Tein SS's and I think the only way to get to it is to remove the seat? How do I get the seat off?
For you "do a search" guys...move on, don't bother posting! Thanks!
Old Apr 2, 2004 | 08:24 PM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
there is three bolts holding the entire back seat in -
I think they are 8mm maybe 10mm. Look where the seat belt attaches to the frame, you will see the bolts there, not the seat belt bolts, they can stay in. The back rest has to come out first, take a look for all the bolts along the seam where the seats join. then pull the back up about 3 inches,The seat has clips across the top that snap the seat down. you will be able to route the seat belts around the back rest. The bottom seat will pull up from clips in the front part of the seat and the back shares the bolts from the back rest. Hope that will help!! good luck
Old Apr 2, 2004 | 09:05 PM
TL-S driver
thanks!
Old Apr 2, 2004 | 09:12 PM
kman156's Avatar
don't damage the 3 top plastic clips that go on the brackets!
they cost $22.00 each!!!
Old Apr 2, 2004 | 09:21 PM
WHAT!!
I had to get a new "A" badgge for the engine, the cost was $12CAD, not too expensive, but there is two tiny tiny, one-way lock-washer you slide around the two posts on the back of the symbol, to hold it on. they were $2.50 each!! I am not kidding about size, both of them would fit on my pinky nail! These things are punched out of a huge sheet of aluminum. and Acura is aelling them off at $250 a piece, in a sandwich sized bags for each of them.
Old Apr 2, 2004 | 09:26 PM
SC TL's Avatar
http://www.abunchofcars.com/diy_page...d_rearseat.htm
Old Apr 2, 2004 | 10:32 PM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
Cool good to know. The dealer took out my rear seat to fix a trunk water problem I had
Old Apr 3, 2004 | 01:08 AM
kman156's Avatar
Talking what's really ridiculous is
there are 2 plastic clips that go into slots in the frame for the seat bench that are made w/ twice as much plastic and cost like $2 dolllars! i don't see the reason why there should be such a high markup between the top plastic anchors and the bottom? later boys, back to zainoing the baby!
Old Apr 3, 2004 | 01:19 AM
NYDesi80's Avatar
Hhaa... dont you wish you had the EDFC installed now Eric. N e way... how's the hand doing?
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
d.lim
Sep 15, 2015 08:54 PM
truonghthe
Sep 7, 2015 11:17 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
