Awsome Sway Bar~~!!
oh man~!!
I thought my 18"+lowered was good enough but after i installed sway bar on rear side, oh good ness. no more body roll during hard cornering. I think every TL owner should get this sway bar. A+++
(you know your stock car is bout to flip when you make a sharp turn..so get the sway bar now!)
i changed both and am very happy... i dont think i get too much oversteer now, and after lowering it with comptech springs i can throw my rear out at will... still learning to do that though (tons of fun)
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Custom Cross-Drilled Front Rotors / Alpine CDA-7863 Head Unit / Alpine G320 EQ / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by
Alpine MRV-1002 amp / Dual 10" JL Audio W-3 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers
Pics of my TL
Pics of my TL
You Gotta Have Sways!!!
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
My AcuraTL Homepage
I Gotta Have Sways!
Dec 5? Weak.
Alumapro BP-10, ZX400TI Phoenix Gold, Python 1500 ESP (remote start, all windows up & down, sunroof closes, prox, etc), burlwood dash kit and shift knob, factory spoiler. Inspire tails baby!
Nate's ride!
Dec 5? Weak.
Nate's ride!
Originally posted by joriki:
What does a sway bar do to decrease the body roll? Increase frame stability on the sides? Do you have pics of what they look like once they're installed?
its the same way as if you had a long bolt with 2 wrenches on each end. if you pull up on one wrench it will try to turn the wrench at the other end. if you connect the 2 wrenches, 1 to each wheel and attach the bolt to the underside of the car moving one wrench moves the other. so the body roll is eliminated.
hope this helps!
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
Originally posted by preludeshfan:
the sway bar is basically a U shape the ends of the U connect to the A arms on each wheel left and right. the bottom of the U shape is where the frame of the car connects. when you corner the inside wheel moves down while the outside wheel moves up. this action causes the U shape to be twisted. the sway bar size determins the amount of twist that is allowed. basically the outside wheel is prevented from being pushed up into the fender well because the wheel on the other side is being pushed up into the fender well by the sway bar because both wheels are basically tied together.
hope this helps!
hope this helps!
I didnt change the front one, but i'm kind of curious bout the result for having both.
then again, i dont think it'll be that much different. anyway i definitly recommand sway bar, not a wasting $$$. now i can corner w/ confident.!
The don't see much of an advantage to installing the rear sways only...In my Miata, when I was looking to install sways, I was only recommended to install the fronts because I would get crazy amounts of understeer.. I would change 'em both in the TL, which is exactly what I'm planning to do..
Ed
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails
Pics of my TL
Pics of my Miata! Wadya think?
Ed
Pics of my TL
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
