automatic windows...
Old May 20, 2009 | 01:04 AM
dso's Avatar
dso
7th Gear
the automatic window button for my drivers side just stopped working. it still lowers and rises, but won't do it after i depress the button. does anyone have an idea as to what could be causing the problem?
thanks
Old May 20, 2009 | 08:28 AM
Jonesi's Avatar
What year TL?
Old May 20, 2009 | 12:38 PM
ftLauTL's Avatar
Ya....It's an Acura
I have the same problem, I have a 2000
Old May 20, 2009 | 01:40 PM
NSXNEXT's Avatar
So you're saying when you push it down till it clicks it doesn't go down automatically? Sounds like the switch is bad.
Old May 20, 2009 | 02:17 PM
HosTL Moderation's Avatar
AM Flakes still Drippin'
This worked for me when I had the same problem. Try pressing and holding the button down as the window rolls down. Keep holding it for 3-4 seconds once the window has fully opened. Do the same for rolling it up (again hold for 3-4 seconds once closed). This seems to reprogram the switch.
Old May 20, 2009 | 03:45 PM
JRhodes88's Avatar
Need an OEM lip kit on my
I have had the same problem a couple times when I had my battery disconnected for a long period of time. This should work to fix the switch.
Old May 20, 2009 | 06:52 PM
fsttyms1's Avatar
This only works on the 02-03 which has the auto down/up feature.
Old May 20, 2009 | 08:32 PM
ftLauTL's Avatar
Ya....It's an Acura
hmmmmm
now it wont go down at all, im thinking maybe the motor is bad?
Old May 20, 2009 | 08:57 PM
Gfaze's Avatar
S E L L
Originally Posted by ftLauTL
hmmmmm
Sounds like your switch is finally toast.
Old May 21, 2009 | 09:17 AM
ice2fire11's Avatar
^^ ive got an extra drivers switch. but im in need of a passenger switch...
Old May 21, 2009 | 01:06 PM
ftLauTL's Avatar
Ya....It's an Acura
thanks bro
Old May 21, 2009 | 09:32 PM
mrkatt's Avatar
will the 02-03 switch fit and operate in a 00 tl for the automatic up and down front driver window?
Old May 21, 2009 | 10:02 PM
Gfaze's Avatar
S E L L
This question has been asked before and unfortunately, no.
Pham Alvan
Mar 16, 2016 09:17 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Houston
Oct 8, 2015 01:27 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
