Auto Tranny converted to Manual... Possible?
Sorry if this sounds lame, but is it possible to change a automatic transmission into a manual transmission. Would be too expensive? Are there manuals that can fit into a TLS? How about the Accords?
Any thoughts would be great.
rat
rat
TL-S driver
yes it would fit, you would have to pretty much get all the components from the CL-S 6. So to answer you question, it is possible...BUT, it would be expremely expensive, to the point it wouldn't even be worth it. You'll not only have to change the transmission but also the interior to fit the manual. Defintiely NOT worth it.
Received 1,080 Likes
Read this thread and it will explain it all.
https://acurazine.com/forums/showthread.php?t=154463
Cliff notes: Not without a ton of money and expertise in custom fabricating, welding, wiring, electronics.....
i looked into it after my 3rd tranny failed. i found all the parts for about 5k. (i was able to find the front clip of a cls in a salvage yard, that i could have gotten all the parts) the big thing is labor. the more you can do your self the cheaper it is goign to be. the other big problem like nsxnext said was electrical. from every thing i found that was gong to be the biggest hurdle. if you are going to pay someone to do this all you are looking at serious $$
Originally Posted by mech
Are there aftermarket dsg FWD transmissions? That would be sweeet...
Originally Posted by fsttyms1
yes velocity resources makes a beefed up tranny
I wonder if they use an OEM tranny and simply modify it, or do they reconstruct the entire tranny from scratch?? Hopefully if they do use an OEM tranny, the first thing they do is install the oil jet kit, and somehow lubricate the "3rd gear clutch pack" a lot better, so it eliminates the possibility of failing on you.
I would only invest money into a solution that actually works. No point in upgrading your tranny if it's simply gonna fail on you after less than 50k miles.
Originally Posted by sc354
are these trannies less susceptible to failing like the ones from acura do???
they use the factory case but all teh internals are custom and titanium, and cryo treated
ya I figured that. There's no way our stock trannies can be considered "performance enhanced" cause they downright suck. I'm at 46k km on mine (30k miles) and it's starting to feel "not like it used to". I'm expecting my tranny to crap out sometime this winter...damn acura's.
hope its not going
Anyways, it's something I have to live with driving a TL. I just made sure that I'm ready for when it happens, by having acura roadside assistance saved in my cell phone (which is always on me). This way if the tranny does crap out, I simply call the roadside assistance and get a flatbed to tow me.
Received 2,329 Likes
Switching from an automatic to manual is NOT cheap. I've looked into it myself.
lanechanger
10-13-2015 10:56 AM
