Auto Tranni Fluid
Old Aug 12, 2008 | 07:30 PM
99TLhot's Avatar
Auto Tranni Fluid
hi i wonder if the 99TL use the same ATF as the honda does? let me know. And does any one have there ATF drain? i plan to do a fluit change on my TL, can any one give me any idea of how many quart of ATF do i need? any tip let me know thanks.
Old Aug 12, 2008 | 08:06 PM
Rajca's Avatar
wham bam thank you ma'am
yes honda atf is the same thing. just search for a 3x3 trans fluid drain and youll be set. everytime u drain it u fill it up with 3quarts (just a little bit more than 3) but on your final fill check the level and top it off. DO NOT OVER FILL
Old Aug 13, 2008 | 06:07 PM
wowzer's Avatar
Yes, use the Honda ATF. My question is how often should the ATF be changed? I recall reading in the manual that it was like 10 yrs or 100,000 miles. IS that right?
Old Aug 13, 2008 | 06:35 PM
Rajca's Avatar
no not right
about 30k miles, some ppl do it around 20k just to be on the safe side.
Old Aug 13, 2008 | 08:07 PM
01tl4tl's Avatar
acura used to have a high change interval that keeps coming down on the new cars
Its because of the problem the 5 speeds have with the clutch packs
scroll thru the gen2 threads for anything that says 3x3 trans fluid
there is a plug on the bottem rear of trans- big letters ATF on it- the other drain down there says OIL, its for the engine
basically you warm the car up dring 10 miles then drain 3 qts- the trans holds 7.3 but will only give up 3 at a time
add 3 new HONDA ZR1 fluid drive 5 minutes around the blovk makling sure to go up and down thru each gear including park so the old remaining fluid is pushed from the valves and such into the drain pan, drain 3- add 3 drive 5 drain 3 add 3
Only way to check for full level is drive 15 minutes cruising on freeway
then pull off offramp and turn off engine- pull and wipe dispstick off and reinsert- remove
check dipstick- engine OFF-- it should be close to the upper dot
anywhere between the dots is ok- it gets higher on the reading with more heat in it...
Old Aug 13, 2008 | 08:17 PM
SupaRookie's Avatar
Kang Ho
My mom friend help us do a tranny drain, but it was a little bit different. He drain, and then add in 3.5 bottle and I drove around. The next day, he draine some more and left it there for about 2 hrs. He pour in 3.5 bottle and ask me to drive around. I came back and he added .5 bottle. My mom drive a Toyota.
Old Aug 14, 2008 | 06:52 AM
Luke7's Avatar
WNC Real Estate Sales99TL
I change my fluid every 10,000 miles or every third oil change. It's easy to do and hopefully by using cleaner fluid my tranny will last longer.
Misinformation above. The proper way to check the Tran. fluid level is with the car warmed up and sitting level with the engine off. The 15 mins. of highway cruising etc. is not necessary and will only confuse people here. The fluid will expand when it's warm or hot but it's not necessary to drive 15 miles to check it. We need to check it when warm, sitting level, engine off.
Old Aug 14, 2008 | 10:45 AM
01tl4tl's Avatar
Thats straight from my 01 TL owner manual on checking fluid level- acura checks it HOT normal driving condition
Old Aug 14, 2008 | 11:28 AM
fsttyms1's Avatar
Wont help. I did it and mine failed as usual in the usual amount of time (actually less miles than the others had)
Old Aug 16, 2008 | 09:41 PM
99TLhot's Avatar
[IMG][/IMG][IMG][IMG]jpmg[/IMG] [IMG][/IMG] THank for the tip guy!!!!!!!! Yea i change The ATF today, and it only come out 2 1/2 quart, and i put 2 1/2 quart back it, the car shift a little smooth now, i plan to do that again on my next oil change sence i got 4 quart of ATF. The car had 159,000 miles and i use castro syntec 10-30, What you guy think? and yea how do you insert pic, so i can show how i do DIY M45 Projector in my 99 TL and 03 civic fog on my bumper,
Old Aug 17, 2008 | 12:35 AM
DC4KiD's Avatar
I change my mom's 00 TL transmission fluid at every oil change (just drain and refill). I notice that if I don't change it when it hits 6K miles or so, the fluid gets very dark (almost black).
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
lanechanger
Oct 13, 2015 10:56 AM
Cexarin
Sep 23, 2015 07:43 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
