Auto Starter Problem.... any ideas???
Old Nov 23, 2004 | 11:12 PM
BJSTLS's Avatar
Hey all......
I have a DEI Remote starter. When it is warm outside, it works like a dream. When it starts to get cold, the problems begin!
Basically, when it is cold and I try to use the remote start, the car continuously cranks but never actually starts. I was told that if the battery voltage dropped below 9v than it would not start by design. Using this theory, I put a volt meter on the battery and then try to remotely start it....... It never even got close to dropping to even 9V, so I think that theory, although valid, may not pertain to my car.
On another note, after about 3 attempts of starting the car and it continuously cranking, it will start. If I then stop the car and remotely start it again, it works fine. If the car sits for about a half hour, I'm back to the cranking problem. On a nice warm day..... it works beautifully.
Any ideas on what could be causing this or what I can do to fix it?
Old Nov 24, 2004 | 02:53 AM
962.5tl's Avatar
sounds like the place that did the car didnt run a tach wire. basically the wire tells the alarm that the car is started or not, and it will adjust the crank time accordingly. e-mail me at griz8469@aol.com if you want me to take a look at the car i live in the area and professionally install alarms and remote starters.
Old Nov 24, 2004 | 10:55 PM
BJSTLS's Avatar
You got mail!
Popee
Dec 20, 2015 12:08 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
agupta3224
Sep 22, 2015 08:08 PM
