Auto dimming rear view mirror with compass
Well a couple of days ago my rear view mirror went tits up (famous bubble and leak). I thought about just buying a new one since the free replacement offer isn't happening anymore, but then I remembered about the mirror (GNTX-177) I bought last year on ebay. I was going to try and mod it to fit, but I never got time to do it, plus my mirror was fine.
Well low and behold, mirror goes tits up and the idea came to mind to do it and try and save money, plus have a nice compass in the car to boot. It wasn't easy, but I was determined to mod it. So out came the dremel and cutting into the new mirror to remove the bracket. Then cut the hell out of the old mirror for the backing and use it as a donor for the bracket since Acura decided to go with a non-standard mount (fuckers!!). Some soldering, drilling, more dremeling, screwing, painting and bingo...I have a compass with a new dimming mirror!!
From the outside or inside you can hardly tell its been modded to fit unless you look for it.
Here is the new mirror with the bracket cut out and the back of the old mirror for the donor
Wiring and donor attachment completed
Installed and compass calibrated. The compass module was velcroed next to the mount.
All done and now its time to clean up all the plastic chunks on the carpet and call it a day!!!
My TL can do this, too!
Originally Posted by OntarioTL
...Then cut the hell out of the old mirror for the backing and use it as a donor for the bracket since Acura decided to go with a non-standard mount (fuckers!!)...
Originally Posted by rob-2
Is there a way to hook up one of those mirrors that tells you miles left on a tank or current mpg?
Originally Posted by DC3328
duuude u should of made a diy
There is a lot of dremeling to do, and some wiring, but if you are carefull and able to pick up the type of mirror I did, you probably could do it yourself without my assistance. Look at the pics, you can see what I had to do to cut out what is needed, but when cutting out the plate from the TL mirror, you have tear that bitch all apart to get at it.
But if you have a perfectly good mirror, well the cost of the mirror with compass and destroying your original mirror that works fine, is not worth the money. I only did it because mine crapped out and I just happen to have a mirror in my closet.
I didnt do a DIY as I was just flying by the seat of my pants, I didnt know if it was going to turn out. I was ready to go out and buy a new mirror.
I'll help out anyone who wants info on how I did it, but no DIY. Already 1 year late on my other DIY.
Originally Posted by JakerfTL
ya my mirror did the big bubble in the middle but im too lazy to replace it
Good mod though. If I can get my hands on one of those mirrors I'd love to do this. How much did that mirror run you by the way, dont mind me asking
I think it cost me about 70 bucks with shipping from Ebay. Just do a search for GNTX-177 you'll find them. Its cool as even the compass has a auto dimmer for night time so its not as bright as day.
I only did this mod because the damn dredded bubble in the first place. Why spend a few hundred for a mirror when I have a perfectly good one sitting in my closet?
Regional Coordinator (Texas)
Nice work.
how did the wires worked out? did u have to figure it out or was it just positive and negative? also the wiring for the compass if any?
I should be getting one pretty soon!
also is there a button to turn off the auto dimmer?
12volt Technician
1 Post
" I was determined to mod it. So out came the dremel and cutting into the new mirror to remove the bracket. Then cut the hell out of the old mirror for the backing and use it as a donor for the bracket since Acura decided to go with a non-standard mount (fuckers!!).
I was scared. but you did an awesome freakin job man.
lol you should see have seen my mirror it was totally fucked for a while after it fell off my window one day (in the middle of a turn)
rockyboy
12-06-2022 02:29 PM
dre707
09-08-2015 08:32 PM
