Anyone replace the stock sub?
i was wondering if anyone replaced their stock sub with a new 8 inch sub...and if you have to wire a new amp to it as well. i havnt looked but i believe the sub has a stock amp too?. regardless im goin to take it out because it rattles when my 12's are knockin.....
If anybody did replace it, how was the quality and was it worth it....???
If you have 12's you dont even need that 8 then. Pull it out and let the vibes of the 12' come through. Anyway, the stock sub has its own amp "100w" behind the rear seat. People have tried to replace it with another free air sub, but it sucked. Your best option is use your current 12's.
honestly when I put my JL 10W7 in, I left my stock sub in there, just disconected it, and I never hear it rattle, even with some insane bass hits.
back to the topic, don't even waist your time trying to replace that small stock sub, throw in your 12's with a new amp and some new wiring and you'll be very happy you did.
Certified Rageaholic
2400 Watts in a TL...Why?
1 Post
FREE AIR 8" SUB..... Put an 8" sub that is supposed to be in a box, and it'll sound $hitty.. The speaker is designed to get a certain ammount of back pressure... A sub designed for a box (most of them unless specified) will sound crappy if it was installed free-air.. I think Kicker makes a free-air 8inch sub that works..
Check in the Offtopic section, you will be able to get wireing diagrams and everything you'll need for this project.
cool guys thanks for the input but i think im gonna take out the old 8 and slump the twelves......
got alot of work to do.....
new capacitor....
new box to build....
dynamat the whole car.....
new highs hopefully...
and a new indash.......
but first a tune up......!!!
new capacitor....
Tristate ViP Crew
Originally Posted by NSXNEXT
Kicker RMB8 will fit in the space.
Originally Posted by CL Platano
That's the one I bought but I'm not sure if I want to install it.
Tristate ViP Crew
Originally Posted by fsttyms1
Why not?
certain resonant frequencies. Not pleased with it at all. The RMB8 looks
like a mid-range unit. Is there any good drop-in replacement for the stock
one? Searched on-line but really did not come up with anything.
/Steve
運転することを愛
The Bose system doesn't have an 8 inch sub, its a 9 inch from what I have heard in the past. Very hard to find another 9 inch. You either need an 8 inch with extended mounts or to build an MDF or similar ring to mount the 8 inch to.
Just chillen..
My 1 12" Comp VR is loud, Im using 2 Ohms on my sub, since my sub came 4 ohms.. I also have the 9" hooked up still with the the 12".. Im using the 9" for a live wire and the best feature I like about it, is I can control my bass from my stock headunit. Both decrease and increase at the same time..
Joseph Stansbury
34
12-04-2015 01:57 PM
yahelou
09-06-2015 09:12 PM
