Anyone know the positive battery cable wire gauge?
The corrosion from the battery posts has seemingly "infected" the positive battery cable itself. I have a universal clamp on there now that is holding fine, but there is still corrosion coming from the copper part of the cable.
Instead of spending $100 on a whole replacement cable, I was thinking of something like this:
Whats the gauge of the wires coming into the stock postive post clamp? I *think* they will fit, but was wondering if anyone knew the actual size (the part Im looking at is good for as large as 4 ga)
Thanks in advance.
-Chris
Thanks in advance.
-Chris
Do ya have enough slack in the cable to be able to cut off the "infected" end to replace the battery terminal's post clamp with a new one ?
Plus since the cables seem to have corrosion in them, I figured Im better off cutting them back a few inches and inserting into that splice setup (which has about 6" of cable dangling from the clamp, to make up for whatever I cut back)
I recently ran into the same issue....except it was the negative ground wire from the battery. Check some auto parts stores or battery wholesalers for replacement battery cables and clamps. I made my own and used an "oversized" Fleet Terminal type for the post clamp. It'll allow the ends of two wires to be installed into it.
If I knew the wire gauge of the positive cables, I might be able to get a car audio type clamp that has 2 outputs. But most Ive found are for a max of 4ga wire, which is fine if thats what the stock wires are.
The "oversized" Fleet Terminal was an Autocraft brand which was purchased from Advance Auto.
Get a thick stranded wire cable from a car audio shop cut to your length. I installed 0-gauge for all the negative and positive cables. Soldered larger terminals on them with a blow torch and plumbing solder. Got 30ft of 0-gauge Chinese copper stranded cable for $40 online.
There are lots of different styles of battery post connectors that will accept multiple terminals. If you want, drop into a car audio store and they will give you one that solves your particular issue.
But here's what I used:
http://images.gasgoo.com/MiMgIzQ0MTk...nal-a104-2.jpg
I removed the wing nut and got a regular hex nut from Home Depot along with a washer so I can tighten the multiple terminals on there for good contact. This setup is much cheaper than fancy car audio terminals and allows me to connect multiple runs of power cables for my audio system....among other things.
MetalGearTypeS
08-29-2016 08:28 PM
SUPRMN84
10-07-2015 09:46 PM
