Any solution to this problem? Seen it before?
Old Jul 21, 2003 | 07:57 PM
TLProspect's Avatar
Arrow Any solution to this problem? Seen it before?
I just got my 2000 TL, and there is a problem I noticed- you know how the armrests attached to the doors in the back are vinyl and padded with the black plastic strip in the middle that contains the ashtray and power window button? Well the vinyl is seperating a bit from the middle black plastic area and it won't stay when I push it back in. Any solutions because I would hate to send it to the Acura dealer and have them charge me an arm and a leg just to see it?
Old Jul 21, 2003 | 08:09 PM
they wont charge you to look at it, they may even offer up a good solution if you go there on a semi regular basis. if not, you can always refuse their service after they look at it right?
Old Jul 21, 2003 | 09:41 PM
I have this problem in my '99... on the driver's side. I just learned to ignore it. In fact, I had forgotten about it until I read this post!
Old Jul 22, 2003 | 12:34 AM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
HAHAHAHA
Old Jul 22, 2003 | 10:53 AM
Deets's Avatar
DUDE! I have this problem...
I just bought my 2000 last week. I have this problem on the passenger rear door. I don't know if it was like this when I bought it. I would have thought that I would have noticed it.
Anyway, I am having a local dealer replace the armrest on Friday. Thankfully, I am still under warranty.
After it is done, I can post the part number and cost if you like.
Old Jul 22, 2003 | 10:59 AM
Tom Blasing's Avatar
is the Mighty Favog
My 94' Talon did that and I too was looking for a way to fix it. I tried super-glue and stuff like that but it just came apart again.
Old Jul 24, 2003 | 12:25 AM
TLProspect's Avatar
So nobody ever found a "cure"?
Old Jul 24, 2003 | 11:20 AM
Deets's Avatar
As far as I know, the cure is to replace the door handle. Which I am having done tomorrow.
Old Jul 24, 2003 | 03:30 PM
Wow I notice new things all the time because of this board. I noticed both of mine are separating a bit but not enough to bother me. I would have never looked or known otherwise. Has anybody tried the Epoxy resin that you have to mix? I know for a fact that will work for you but be sure you dont get it on the switch. I had a similar problem with my previous lincoln and it worked great no matter how hot or cold it was.
Good luck
Old Jul 25, 2003 | 09:08 AM
Deets's Avatar
Okay! Just got back from the dealer's service shop. I had them replace my rear passenger door handle/trim. Looks great, and only took about 1/2 hour.
The part number is:
83734-S0K-A00ZA
I do not know the cost. It was replaced under warranty.
Old Jul 25, 2003 | 09:53 AM
Darkshear's Avatar
l33t
i got it here too. drivers and rear drivers. the rear is REAL BAD though... looks like the glue just gives way. dealer should take care of it.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
AcuraKidd
Sep 25, 2015 11:18 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
