any alternative caliper..besides the acura legend
Old Feb 19, 2014 | 08:15 PM
Nizmo_max's Avatar
was thinking if anyone tried using the stock s2000 caliper? fronts or rear fits? reason why I have a set laying around and search but didnt find any info. beside the acura legend calipers..
Old Feb 19, 2014 | 08:25 PM
The problem with putting other car's brakes on, is you might upset brake Bias.
Honda engineers put together your brakes specifically for your car.
if you upset brake bias, you might end up stopping LONGER.
Old Feb 20, 2014 | 08:03 AM
Nicks2001tl's Avatar
I had a rear motor mount hanging around and my front motor mount went out thought about using the rear in the front because the screw hole lined up. Bought a new front mount. Why? Because that`s what goes there.
Shop around for some decent calipers aftermarket work just as good if not better. Check rock auto. The legend two piston calipers work good and for the price you can`t really ignore that option.
The s2000 calipers probably can be sold and put that money towards new calipers. Always replace your brake components in pairs otherwise you risk an imbalance in your braking system.
Old Feb 20, 2014 | 08:14 AM
cincinattlguy19's Avatar
06 NBP 6MT TL
There are the various Big Brake Kits (Brembo, Wilwood, Rotora, etc.) and then some guys even use the 4-pot RL brakes with a custom bracket. The cheapest and best bet is probably just sticking with the Legend caliper!
Soul_Deamon
Nov 13, 2018 04:44 PM
chrisr
Dec 4, 2015 02:17 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
Phambam12
Sep 6, 2015 06:57 PM
