Alignment problem, seized rear toe bolt
Old Jan 31, 2009 | 04:49 PM
sbuswell's Avatar
I need 2 more gears
Today I had some rubber put on my car, Yoko V4S tires and got an alignment. The alignment tech said the left rear toe adjustment bolt was seized so they couldn't adjust the left rear toe. Below is a copy of the alignment sheet. The front casters are off, I know they can't be adjusted. Based on this print out what should I do to correct the problem?
Old Jan 31, 2009 | 04:58 PM
sbuswell's Avatar
I need 2 more gears
not sure why the pics not working, but the left rear toe is -0.01 and the right rear toe is 0.10 for a total rear toe of 0.09. How can I fix this.
Old Jan 31, 2009 | 04:59 PM
MurdaZ's Avatar
Old Jan 31, 2009 | 05:05 PM
sbuswell's Avatar
I need 2 more gears
thanks MurdaZ.
Old Jan 31, 2009 | 05:22 PM
hellas's Avatar
you can adjust caster by removing a shim on the radius rod and you need to change the toe bolt. not very hard
Old Jan 31, 2009 | 05:52 PM
sbuswell's Avatar
I need 2 more gears
so changing the toe bolt alone is possible without having to change the control arm too?
Old Feb 1, 2009 | 03:05 PM
hellas's Avatar
yes, unless it is so badly seized that you cant hammer the old one out
cycdaniel
Dec 17, 2019 10:58 AM
james357
Feb 13, 2016 02:37 PM
Zonian22
Nov 14, 2015 01:20 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Zonian22
Sep 2, 2015 08:19 AM
