Alignment Problem
Old Apr 11, 2005 | 12:43 AM
Angry Alignment Problem
Ever since I dropped my car I can't get it to go straight, no matter how many different places align the car. I do have the spc camber kit all the way around, and now it pulls to the right. The place I went to said everything is in specs and it shouldnt pull but yet it still does. Would me sitting in the car while they do the adjusting help?
Any ideas?
Old Apr 11, 2005 | 12:46 AM
Pure Adrenaline's Avatar
Dragging knees in
No, unless you weigh like 500 pounds.
Can you post the alignment specs? Just curious. It will tell us more.
Old Apr 14, 2005 | 10:53 PM
OK here are the specs
Left front right front
.1 deg. camber 0.0 camber
3.2 deg. caster 3.4 caster
.01 deg. toe -.01 toe
front
.01 total toe
.01 steer ahead
left rear right rear
-.5 camber -.5 camber
.06 toe .09 toe
rear
.15 total toe
-.02 thrust angle
Old Apr 14, 2005 | 11:06 PM
Dragging knees in
In the front, your toe spec has both wheels pointing to the right at .01 degree. But it's really not that much of toe, so I wonder why it would pull like that.
Then again, the caster on the passenger side is great than the left, so combined with the toe, I guess it's enough to pull to the right.
Old Apr 14, 2005 | 11:24 PM
benzo555's Avatar
boo
Sometimes your tires will do it. Where did u take it to??
Old Apr 15, 2005 | 09:50 AM
fsttyms1's Avatar
the alignment specs are fine. as for whats causing the car to pull, it could be a wheel bearing, tranny, or tires
Old Apr 15, 2005 | 10:58 AM
Even if the tires are new???
Benzo I took it to southwest alignment
Old Apr 15, 2005 | 07:39 PM
beebus's Avatar
3rd Gear
how much did you pay for an alignment? just curious
Old Apr 16, 2005 | 04:31 AM
Lawaia's Avatar
Moderator Alumnus
Brake caliper possibly binding?
Old Apr 16, 2005 | 01:55 PM
benzo555's Avatar
boo
Just take the car back to them.. My had to bring my car twice and it was determined my back tires were a lil cambered so it pulled. They should be a ble to tell you whats up. sw alignment has been great to me.
Old Apr 16, 2005 | 03:00 PM
unlemming's Avatar
Smitty's Moral Police
Define "new"? It only took a couple thousand miles (if that) on my tires before they were ruined by my camber/toe being bad (before I got the camber kit on). And it wasn't even that far off cause they adjusted it as best they could..something like -1.2 w/ H&R Sports and Tokico Illuminas..worth checking out anyway, swap the tires and see what happens.
Old Apr 17, 2005 | 08:53 AM
etxxz's Avatar
@ slide or die @
GUYS, it can be as simple as the roads themselves
or it can be the tires w/ uneven wear, but as far as my experience goes i have NEVER been in a car that doesnt pull to either side because the roads, EVERYWHERE, believe it or not...are pretty damm slanted
Old Apr 17, 2005 | 11:48 AM
Its probably your tires, ask them if they can do a straighttrack roadforce balance. The newer Hunter machines can tell you where to put each wheel to get the least pull or vibration. I recently bought a set of Yoko AVS's and I had to balance them three times before they stopped pulling. The third time I used the straighttrack and it worked great.
Old Apr 19, 2005 | 02:21 AM
100 mi. on the tires....
Old Apr 19, 2005 | 11:19 AM
chilifrost's Avatar
What's a place that will do straighttrack balance.
Old Apr 19, 2005 | 01:59 PM
Its just a function of the machine. If they have a newer Hunter machine(balancing machine) they can do it. Any time I have a car come in with vibration or pull I do it and I have never had a comeback. Ask whoever you take it to if they can check the roadforce of your tires. Straighttrak is an upgrade to roadforce, it tells you what your roadforce is and how much pull the car will have with the tires in different positions, any good shop should be able to do roadforce but they might not have a straighttrack machine.
Old May 3, 2005 | 01:05 AM
any other ideas? I had one set of tires trashed bc of alignment I dont want another.
Old May 3, 2005 | 03:06 AM
Dragging knees in
If you don't have non-unidirectional tires, then switch them around and see if there's a difference. If there is, then you know it's the tires.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
