Aem Pullies From Hell Are Annoying Me
Old Nov 1, 2002 | 06:06 PM
Rice1304's Avatar
Thumbs down Aem Pullies From Hell Are Annoying Me
My pullies have recently been making chirping noises like hell. when the car is idle, it makes the noises and it is even more apparent when i give it some gas. I tried to apply lubricant to the belt but it only helps for a day -- the very next day the annoying sounds start again. Could it be the tension of the bolts? Please help.
Old Nov 1, 2002 | 07:52 PM
NighthawkBlack's Avatar
See if its your alternator making the noise or get UR pullies they are way better.
Old Nov 1, 2002 | 08:37 PM
IXLR8TL3.2's Avatar
try the old "soap on the belt" trick.. use a bar of soap
Old Nov 1, 2002 | 09:20 PM
kman156's Avatar
Exclamation belt tensioner!
if that doesn't work go to pep boys and buy a belt that is .05" smaller than stock. that would be the next size down. the squealing is most likely a loose/ stretched belt. especially if you you used the original belt when you swapped pullies. i had the same issue. new belt solved the prob! kman
Old Nov 4, 2002 | 02:23 AM
AcuraTLDriver's Avatar
I got the pullies on my car and have not had any issue so far (knock on wood). The squeaking is probably from your alternator.
Old Nov 4, 2002 | 08:51 AM
numbaonexstunna's Avatar
who installed them???
balanced performance here in georgia did mine, they do a real professional job.....i guess thats y they charged me for 2 hours = 150$ but then they gave me 50$ discount cause i went there often for installs. but my pulleys are great.. no problems at all. had them for probably about 10,000 miles now
Old Nov 7, 2002 | 09:58 AM
dogshyne's Avatar
Why don't you put the part back on your car that the factory engineered to work with your car?
Old Nov 7, 2002 | 11:37 AM
Nate's Avatar
If it is the belt making the noise, take a wire brush and hold it gently against the side of the belt while it is spinning. Works everytime.
Old Nov 7, 2002 | 11:41 AM
hchhon's Avatar
Nate did you received your rings yet?
Old Nov 7, 2002 | 12:58 PM
NSX4dr's Avatar
Original Member #81
Because there is no problem modifying any car. The cause is the belt.....it's too long, use the stock belt, it's tricky but it works.
Charles
Old Nov 7, 2002 | 06:40 PM
edgalang's Avatar
Purchased: April 28, 2001
What does that do? Is that better than holding sand paper to the side?
Old Nov 8, 2002 | 02:47 PM
I feel dumb asking this, but what do AEM pulleys do and why do they improve performance? This seems to be a popular mod.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
jmaxima03
Sep 27, 2015 10:22 AM
kingbharj
Sep 25, 2015 07:25 PM
