AEM CAI problem
Registered Abuser
AEM CAI problem
i ordered it from this site and i indicated that i wanted the 99 model. when i got it and started in stalling i noticed that there were 4 hoses instead of 2. 2 of which had antifreeze in them. I than looked for 4 inlets in the aem piping only to see 2. and the one on the left isnt even big enough for the throttle body hose to enter. I then looked at the sheet that came with my CAI and it said 2000-2003 3.2tl. i am pretty pissed and i really want to make this work. what is going on?!? please help me.. my car is in pieces and i dont know what to do.
thanks in advance,
matt
thanks in advance,
matt
Try this out it will help you out a lot! BTW you have the right intake.
http://www.acura-tl.com/faq/faq.php#1c
you have the right Intake it fits 1999-2003 non S.
1999 - 2003 * will not fit Type S
2.75 inch dia.
Part# 20-402
2.75 inch dia.
Part# 20-402
Registered Abuser
ok, now i figured it out all but one thing, where is the top piece supposed to mount to. its not long enought to mount back up the the stock location, and there is my horn in the way. where does it go?
thanks again.
matt
thanks again.
matt
Registered Abuser
ok we finally got it, i just turned the alarm horn around. got it all mounted and hooked up. its raining tonight and i popped the hood after i was out and about and i noticed that there was water dripping on the filter and there was moisture around it. shouldnt i be concerned about that?
matt
matt
Flyin' and Drivin'
yeah, lol.... I installed my CAI on my 99, and when I removed the small radiator from the intake I had the same god awful feeling about that antifreeze, but I quickly cut out the radiator and bypassed the two hoses and reconnected them to each other, so basically the car doesn't know that it doesn't have that second radiator. I didn't move my horn, cause I dont know where the hell to put it. I just went to Home Depot and bought 2 metal pipe holders (like the ones that hold the rubber on the CAI pipe) and put one around the horn area, and the other down lower on a small piece of metal between the battery and the headlight assembly area.
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
