Adjust the neutral safety switch/trans range switch?
Old May 22, 2019 | 04:11 PM
CL-Slick's Avatar
Chillin' in my trailer
I recently got my car (2002 TL-P) back from the shop for the AV6 swap and everything is shifting and running great. The only problem I have is that the gear indicator lights on the dash don’t illuminate unless the shifter is between gears. This means my reverse lights don’t come on in reverse and the car won’t go into tiptronic shift mode. Is there a way the switch can be adjusted or do I need to replace it with the used unit I bought?
Old May 23, 2019 | 10:07 AM
MBP 03's Avatar
It's been a while since I did my AV6 swap, but IIRC, the TL range switch gets swapped over to the AV6 and there is room for adjustment via the slotted bolt holes in the switch.
Old May 23, 2019 | 04:23 PM
CL-Slick's Avatar
I’m assuming I need to take it apart to find the adjustments since all I see is the opening where the part coming off of the transmission goes in?
Old May 23, 2019 | 05:03 PM
The attachment is from the CL Helms manual and it should not vary much for your TL-P.
File Type: pdf
Old May 23, 2019 | 05:50 PM
CL-Slick's Avatar
Thanks for the link! I’ll try resetting everything in the neutral position and see how that goes.
Old May 24, 2019 | 08:27 PM
CL-Slick's Avatar
Got it fixed today, thanks for the help guys!
Skirmich
1/2G MDX (2001-2013)
Mar 30, 2020 09:33 PM
spydercatt
Jun 21, 2015 05:26 PM
98BlueStreak
1G CL Problems & Fixes
Feb 12, 2013 03:52 PM
spydercatt
Jan 28, 2013 06:19 PM
Tweek
Aug 29, 2007 09:02 AM
