the added expense of having rims?
6th Gear
Hi, I was thinking about buying 19'' racing type 6r wheels in chrome for my silver 2002 acura tl. With the rims i am going to be getting 225/35/19 toyo prozie fz4 tires, which are z rated. I was wondering How many miles i could expect to get from these tires? I also wanted to know do i have to lower it and what other expenses will i incurr from buying these rims(Alignment things like that)??
if you don't lower your car, you won't get camber issues and therefore can expect to get the normal/stated amount of miles from normal driving. more aggressive driving will probably lead to less miles. i tried searching but i can't see to find the treadlife for these. now if you lower, you will need to buy the lowering element (springs or coilovers), camber kits for front and/or back, labor and get an alignment. that tire size is within reason, but make sure you get the appropriate rim width and rim offset to prevent rubbing. do you know these two values?
TL-S driver
you don't need camber kits if your not lowering it more then 1.5 inches. Comptech springs for example won't require a camber kit because it's not low enough to effect anything. Some problems you do encounter is the tires only last about 20-30k miles. another is when your lower, you have to watch the deep dips, potholes and the such that can bend the rim or scratch the bottom of the car. But I personally think it's all worth it. Lower the car, you'll love it!
6th Gear
springs....
yeah i know all the specifications i need in regards to offset and width. the rims i picked out you can find here http://store5.yimg.com/I/yhst-158831..._1783_18293415 i am getting them in chrome 19''. for the springs i picked H&R SPORT SPRINGS for H&R SPORT SPRINGS for 02-03 ACURA 3.2 TL, INCL. TYPE-S (-1.75 F -1.50 R)
With this combination what other expenses will i have to pay for besides getting the rims and the springs put on. Someone suggested buying shocks as well??? anyone seen those grills from grill-tech??
also if i do decide to sell my rims/tires ill let u know, but it isnt a type s
thegold91/
Item#: TEIN-SKA34-BUB00 195USD
TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. The line is produced with Vanadium (SAE9254V), which is strong, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more attractive appearance, added performance, and excellent comfort. Includes a one year limited warranty.
Item#: TNB-TNF074 216USD
Normal Feeling is for those who wish to lower their vehicle, while maintaining the comfort of the stock suspension. NF210 lowers the vehicle an average of 1 1/4~1 1/2in (30~40mm) without sacrificing the stock ride quality. This is achieved by raising the spring rate no more than 10%
DONT SWEAT THE STRUTS UNLESS YOU DRIVE HARD EVERYDAY/
AND SAVE THE CHROME FOR THE MONTE CARLOS AND SUVS/
