99 TL TCS light on
99 TL TCS light on
I noticed my TCS light comes on after I drive a little while and won't go out unless I power cycle the car but it will come back after a little while of driving. I replaced both front wheel speed sensors. I still have the same issue.
any suggestions?
any suggestions?
Is the CEL on as well?
Have you been able to pull any codes?
Have you switched the size of your factory wheels?
I suspect it might be the EGR.
whitetiger5 (09-16-2020)
When the TCS light comes on randomly without a Check Engine Light, it commonly throws an EGR lift malfunction code later on. Replacing EGR valve usually solves the issue.
dan lazer
01-28-2011 11:06 AM
