99 tl possible tranny problem
Hi i have a 99 tl with 63xxx original miles, and im wondering if my tranny is starting to go or maybe it could be a motor mount. when i shift into drive or reverse theres a small jump that kind of moves the car a lil.other than that it shifts smoothly while driving. i dont beat on the car at all or use the manual shifting. i got the car with 59xxx last feb 2010 it has 63xxx. i barely drive it. anyways im wondering what the problem could be. THanks
I check mounts by fully applying e-brake, shifting to drive and snap throttling the motor so the engine and trans move, after checking in drive, try in reverse, have someone doing this you trust with your life, while you observe the mounts. Any torn or excessive movement of the engine or trans can mean mounts.
Hope this helps.
Hope this helps.
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
