99 tl with a 01 engine
Old May 15, 2008 | 12:26 PM
blacktlr's Avatar
this is my problem i have a 99 but the tranny was gone so i got a sweet deal on a totaled 01 tl so i bought the entire front clip with a harness and installed it in my 99 with the ecu shift box and cluster and the engine would not turn on with its harness but it does with the 99 dash harness but when u put it in drive its stays like on one gear (((( before taking engine off the 01 tl i tested drove it and it drove like new with only 89xxx miles on it)) now i need your help guys what can i do
Old May 15, 2008 | 01:27 PM
phee's Avatar
I got the Shifts
im not sure i understand... use punctuation
did you use the 01 ECU? or the 99 ECU?
Old May 15, 2008 | 01:28 PM
phee's Avatar
I got the Shifts
did you even try going to the dealer for a warranty tranny?
Old May 15, 2008 | 02:11 PM
fsttyms1's Avatar
The car wont start with the new ECU because of the immobilizer. Your key has to be programmed to the new ECU. (have to bring it to the dealer for that. If you keep the new harnesses in your car and get that programmed it should run right.
Old May 15, 2008 | 11:59 PM
blacktlr's Avatar
i used everything of the 01
Old May 16, 2008 | 07:13 AM
fsttyms1's Avatar
Then you have to have YOUR key reprogrammed to the new ECU. only the dealer can do that.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
