6speed swap
tl_badboy96
6speed swap
wassup everyone. im here cuz i wanna do a 6speed swap to my 99tlp. im on my second tranny and its gonna go sometime. it jerks really bad when i go from drive to rev. it grinds really bad too. im not gonna invest in another tranny. i wanna go with the cls motor and etc parts. im in the begining stages so im taking all info to make the process smooth. if you guys can get or no someone selling any of the parts at a decent price please free to let me know. i think i will start the wrench turning and the tear down process mid nov or early this month.
Look into the modules, it will make things cheaper.
tl_badboy96
Here is a parts/ price list.
Can you guys please look over this and if you can save me a buck please feel free to let me know. i will be doing all the work myself so labor want be an issue.
2003 CL-S 6 SPEED ENGING SWAP J32A2
6 SPD MANUAL TYPE S JUNKYARD
MANUAL ENG HARNESS 32110-PGE-A11 $274.25
ECU
FLYWHEEL 22100-PGE-026 $520.40
FLYWHEEL BOLTS 90011-PGE-000 $2.43 8
CLUTCH KIT 22105-PGE-305 $307.17
REAR ENG MOUNT 50810-S3M-A01 $142.92
MOUNTING BRACKET 50827-S3M-A00 $85.87
BOLT M12X25 90166-S3M-A00 $2.04
REAR&FRNT ENG DAMPENER& BRACKET AFTERMARKET
SHIFTER ASSEMBLY 54100-S3M-A01 $68.72
CABLES 5 4310-S3M-A01 $127.47
STARTER LOCAL AUTOSTORE
GAGE CLUSTER JUNKYARD/ BLACKMARKET
HYDRO CLUTCH LINES TRY AFTERMARKET
TRANNY MOUNTS REAR 50806-S3M-A03 $48.10
TRANNY MOUNT FRNT 50805-S3M-A03 $34.01
CUP HOLDER 77230-S3M-A01ZA $95.23
PARKING BRAKE 4705-S3M-A04ZA $55.08
SPRING 47537-671-670 $1.50
NUT 47522-594-000 $1.04
EQUALIZER PIN 47365-538-000 $0.54
EQUALIZER 47360-SB2-000 $1.82
BY-PASS VAVLE 37850-PGE-A01 $79.76
BRAKE PEDAL ASSY 46600-S3M-A51 $59.67
CLUTCH PEDAL 46910-S3M-A01 $54.47
CLUTCH P BRACKET 46990-S84-A01 $330.64
MAST CYL ASSY 46922-S3M-A01 $61.21
CLUTCH FL TNK 46965-S5A-013 $17.01
CLUTCH HOSE 46961-S3M-A02 $23.22
RLY BX ASSY 38250-S3M-A22 $262.58
SHIFT BOOT 83414-S3M-A01ZA $97.75
SHIFT KNOB 54102-SLO-023ZB $187.73
RT COMP HARNESS 32100-S3M-A12 $235.33
LT COMP HARNESS 32120-S3M-A20 $139.98
UPPER INST HARNESS 32117-S3M-A31 $222.44
LWR DASH HARNESS 32150-S3M-A32 $147.70
TOTAL $3702.73
*PRICE DOES NOT INCLUDE ENGINE, GAGE CLUSTER, AND ECU*
ECU
TOTAL $3702.73
If you get the modules you wont have to swap any wiring. You will be able to keep your motor.
tl_badboy96
hey guys, i just wanted to say thanks for all the inputs. im very serious with this mod, and if you guys know where i can find the eng and tranny at a decent price please let me know. (mod edit)
tl_badboy96
yeah local junkyards have been a non existing to acura parts. its suck though cuz i see a lot tl/cl getting recked here and then they are shipped elsewhere.
They dont have to be local. I got my trans from St Louis, shipping by freight wasnt very much at all. The manual trans is light, you (i was able to) pick it up with 1 arm
xsilverhawkx
09-28-2015 06:51 PM
STL TL-S
09-23-2015 08:52 PM
