6MT Swap in 03 TL-S
6MT Swap in 03 TL-S
Just trying to get some feed back, has anyone done a 6 speed manual swap(from CL-S) into a 02-03 TL-S?
I ended up buying the electrical trouble shooting manual for both my TL and the CL that i would be pulling parts from. I mapped the pin outs of the engine ECU's and was able to map everything over more or less no problem. The real issues start with the ABS/TCS/VSA system.
I guess my real question is has anyone actually done this swap before and with what results? I would like to avoid swapping the ABS modulator and ABS ecu but it might come down to that. Any Help?
Yeah, only thing was you had a TL-P not a TL-S, the VSA system on the TL-S auto kind of throws a wrench in the swap unless I swap everything (ABS control unit, modulator etc. Might end up doing that anyways, but figured i would ask. short of the ABS issue I have found you can do the swap with out swapping harness, just changing connectors and pin outs.
I would be skeptical of anyone getting the full VSA system working with a manual swap. There are quite a few inputs to the VSA computer that are not there on a manual car. There also appears to be some sort of serial communication link between the PCM and the VSA unit. I don't know what it is there for but i doubt it work really work with out that. i think it would be possible to do the swap, but you would really have to swap the VSA system over to the standard ABS/TCS.
I looked at that users threads but I couldn't find anything like that, any links?
You cant get your VSA to work with the manual. ABS can be gotten to work though.
yeah i am not so worried about getting vsa to work, although i am really interested in what goes into the swap. I have followed your swap and unfortunately I am not sure how much applies since you have a 00 TL-P. It looks like everyone has more or less just gotten a wrecked CL-S 6MT and swaped all of the harnesses and boxes over. After tracing a lot of the wires via the oem electrical manual, the major differences look to be in the VSA/TCS system. It would be kind of nice not to shell out all that extra money if I don't have to, and I like a challenge.
MetalGearTypeS
08-29-2016 08:28 PM
xsilverhawkx
09-28-2015 06:51 PM
