6 speed swap Trans Sensor Question
SOOOO guys.. I'm using a 05 TL 6Speed trans for my car... i have an 02 Acura TLS and i have my tls engine, and i'm going full manual (true manual)
the Crankshaft position sensor I just purchased for my car and I need to know if this Sensor is supposed to go to this trans... reason i'm asking is because the the part number i purchased is 37500-pge-a11 and I'm not sure if this sensor will go to this trans... The only reference i have is Phees swap, but he used richies harness.. I'm not going that route...
DEPTLS (08-28-2012)
Right, so i have Manual harness. I have almost all my little harnesses n sensors.. I dont have the Crank pulley and back cover and all that. but my mechanic was telling me that the above mentioned sensor will not fit into the trans. WHICH sensors are supposed to go into the transmission??/
If im not mistaken, you HAVE to use the richie module to run that trans. That trans doesnt work with the CL-S ecu as it didnt have the same flywheel or pickup point for the ckp sensor.
I've been told the Trans Case In being Modified or a inlet is being Milled into the trans case to accept the sensor... Now as for the flywheel and ecu.. it would still be the CLS6MT ECU and the CLS6MT Flywheel will still work... i just need to place that sensor. It's been done by nva-av6 and a few others.. I'm just looking for Specifics... Nobody seems to know that...
cycdaniel
12-17-2019 10:58 AM
justin7779
12-25-2015 10:33 PM
handsom-hustla
11-13-2015 05:04 PM
Skirmich
09-15-2015 06:41 PM
