6 speed conversion, 2nd problem 9/2/17
#1121
I just installed my upper and lower dash harnesses today and I have a handful of extra connetors on the lower drivers side.
#1122
Welp, shift cable decided it was going to snap. Luckily was only a mile or so from home and the 3.7 has enough tq to get the car moving in 4th from a stop light easily enough and able to lunk along to get it home. Time to locate a new one.
#1125
#1126
You had another thread from 2016 regarding code p0386.
Looked like you replaced everything but still had the code.
How did that work out in the end?
I spun a rod bearing on my '03 Cl-S 6mt, dropped in a donor engine from TL-S and have the same code.
#1127
If you decide to replace it in pursuit of trying to get rid of the P0386 code, you can find alternatives to the discontinued Acura part #37506-PGE-A12 on the thread below:
https://acurazine.com/forums/2g-cl-p...ilable-960248/
teh CL (10-09-2017)
RYAN97812
06-08-2017 11:02 AM
2002, 2004, 32, 6spd, 90011pge000, acura, cl, conversion, g35, seed, speed, speeds, swap, tl, transmission
