45K service - quote
Originally Posted by 03CoupeV6
At 45k miles change the oil and filter, the air filter if it needs it, the cabin filter, and rotate the tires if you need it. The rest is fluff and BS.
change oil = $19.95 at any oil changing shop
air filter = $17 at autozone/pepboys and change it urself, takes 5 minutes
cabin filter = $20 at autozone/pepboys and change it urself, takes 15 minutes
rotate tires = maybe like $20 at any flat fix shop or u can do it urself = free
all = much cheaper than $480
Originally Posted by bkzjimmy
in that case.....
Save your money as bkzjimmy suggested. Just do the stuff yourself.
this car doesnt need dealership service ever. Find a shop that specializes in honda/acura - there are a few in nearly every town. they are always cheeper and do just as good of work. For example, I was quoted about $900 for replacing the timing belt by a few dealers, while a local honda/acura mechanic quoted me $650 including replacing the belts, water pump and a coolent flush...look for a place like that for your service if you cant do it yourself
Checkout the hondashop store in Houston. Google for their website. They specialized in Honda and Acura. SterlingMcCall is such a ripoff. They want 250bucks to turn each of my rotor. Yeap, each. For that price, I am sure buying brand new rotors is still cheaper.
QuangP,
Is this the shop you are talking about?
http://www.hondacarshop.com/
btw, if there is stuff that needs to be replaced under warranty, what happens then? Can I take it back to an acura dealer for only that stuff.
Thanks.
Thanks.
Yeap, that what the service advisor told me regarding the price of turning the rotor. I had to ask her a couple of times just to make sure. Replacing the brake pads, just replacing 4 pad, will cost 350.
Thomas--That is the right one. Yeah, for warranty works you should take it back to the dealer of course.
mlody
12-04-2019 02:11 PM
