Please Help 99TL
Old Feb 2, 2006 | 07:34 PM
GreenTL99's Avatar
Pimpn' Ain't Easy
Question Please Help 99TL
Just replaced my starter at the dealer and the also replaced my ignition recalls. They wanted to change my sparks and clean my ECG (?). Can a place like pep boys or someother place do as good of a job as the dealer?
They said it idles low is that the plugs like they are saying?
Old Feb 2, 2006 | 07:50 PM
ou sig's Avatar
Boomer SOONER
dont think you have to pay extra for dealer work...first of all, you can replace your spark plugs yourself very easy and it is the EGR valve they are talking about cleaning. there are instructions on this site on how to clean out your EGR also - I did it on my '99TL and it helped the idle very much.
Old Feb 2, 2006 | 08:15 PM
fsttyms1's Avatar
the 99 also requires drilling of the egr port and a sleve pounded in
Old Feb 2, 2006 | 09:08 PM
ou sig's Avatar
Boomer SOONER
it doesnt "require" it - though it would help to get the part of the port in the lower manafold 100% clean. I just cleaned out the upper intake manafold port and got as much build up as I could out of the lower part...you can spray that carbon cleaner on the port and let it sit a while then suck it out with a shop vac. that cleaned mine out nearly good as new.
Old Feb 2, 2006 | 09:24 PM
fsttyms1's Avatar
for it to be done properly it does
Old Feb 18, 2006 | 11:38 AM
jdsallpltnum99's Avatar
8th Gear
did i get this correct (lemme know if i'm wrong of course) you can clean the EGR without buying the actual kit or valve?
Old Feb 18, 2006 | 01:13 PM
ou sig's Avatar
Boomer SOONER
you can clean the EGR port very easy, but if your actual EGR valve goes out, I believe you have to get a new one. The most common problem is the EGR port gets clogged with carbon and the valve is just fine, so if you take off the intake manafold, you will see a small port on the driver side of the manafold and it will be all clogged up - mine was. Clean that out and it will work fine
NYCdesiPola
Jun 27, 2005 09:44 PM
valuetl
Nov 27, 2001 06:44 PM
acuraguynj
May 12, 2001 01:01 AM
