2002 drivers window on a 99 TL?
Hi everyone,
Anyone know if the drivers side window switch from a 2002 would have the same connections as the 99 TL? I want the auto-up feature.
let me know if you have done this mod.
Thanks.
Thanks.
4th Gear
it should work. The auto up feature is in the switch itself, so as long as the wire will plug in, it should work fine. You can still get it work if the harness plugs do not match up, but it will require you cutting and crimping yourself which might not be worth it.
ഥഎണഡഏ Fellas Inc.
you can try calling acura for the part numbers for each.
or check out http://www.acuraoemparts.com/ if the exploded diagram shows the same part #?
And I'm still looking into modding a mirror switch from later models that are backlit to work in the non backlit switch.
2G wanting 3G
what about that guy who did the one touch sunroof close switch???
he did something behind the switch so he could just tap close and it would close.
something about a 5 second circuit or something?
i couldnt find the thread. anyone know what i'm talking about?
It could possibly be done, but like you mentioned in a post before about the safety part of it. There is no logic built in for collision detection, so pretty much if your hand is in the way, you are F**ked.
kixo
09-25-2015 03:07 PM
