2001 TL Driver Side Headlight / Low Beam takes a while to start
Old Jan 22, 2019 | 11:59 PM
User 12221's Avatar
I have a 2001 TL. My driver side headlight / low beam is dimmer than the passenger side. It also occasionally takes a few minutes to start, so only the passenger side would be on. I replaced both with HID bulbs. They are roughly around the same color now. The problem with the driver side taking a few minutes to start persisted. Has anyone else had this issue and have suggestions?
Thanks!
Old Jan 25, 2019 | 03:53 PM
Arkady's Avatar
Check out this thread: https://acurazine.com/forums/second-...roblem-781734/
Sounds like you might be dealing with a ballast issue, but I'd search for some other threads to get some more info first - since ballasts aren't exactly the cheapest things in the world.
Old Jan 25, 2019 | 08:57 PM
User 12221's Avatar
Thanks! I suspected it might be a ballast problem as well. In the past two days, my driver side headlight has been working fine. Until it becomes a reoccurring issue, I will hold up on the fix.
hondeducation
Dec 22, 2017 02:37 AM
Kevin17112
May 13, 2017 04:49 PM
codj2k
Sep 17, 2014 01:07 AM
clubali1
2G CL Problems & Fixes
22
Mar 16, 2007 02:05 PM
