2000 TL TCS Light / Tachometer Problem
Old 10-07-2010, 09:46 PM
Sanyin's Avatar
Hi, ill keep it simple. Weird problems.
TCS light comes on once in a while and as it does the tachometer (RPM) indicator drops to 0, and kicks in and out every so often and so does the light. Other then that the car works just fine. Any ideas?
Also "Side airbag" light comes on once in a while.
Its possible that its some sort of conection/physical issue as hitting bumps or whatever seems to make TCS/Tachometer go on/off sporadically.
Thanks in advance for any help.
Old 10-07-2010, 10:12 PM
finalcross's Avatar
We have a side airbag light?
Old 10-07-2010, 10:32 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
I hope that was supposed to be in red, final~
if the passenger is out of normal seated position--as in drunk buddy leaned against the window, or having the seat reclined wayyyyy back
then the OPDS measures a differance in weight between seat lower and upper sections from its set parameters- turns OFF the side airbag so in the event of crash- the airbag doesnt break their neck as it deploys in a milisecond
objects placed on passenger seat will also trigger the system
something bad must have happened!!--if there is a safety device.. there was a problem...
Old 10-07-2010, 10:33 PM
Sanyin's Avatar
LOL we have to since mine is on.
Old 10-07-2010, 10:37 PM
Sanyin's Avatar
OHH OHH ok yeah i notice it happens when i have random bags and stuff i throw into passenger seat. GREATLY appreciated.
Thats one light down, TCS and tach to go.
01tl4tl's Avatar
99s had a recall for the ignition switch back, with similar symptoms- engine will shut off and back on while driving, dash lights come on etc
bumps and turns may increase the effect
2000s and later years ~appear~ to use the same part--so its also subject to failure
thats where I would start--under 50 bucks at parts store, see diy section for more
before you buy any parts have the parts store run a free electrical system test-
it cks the wires, alt, batt, starter draw.
Old cables or loose connection can be at fault, car needs steady power
Any blue growth on the battery terminals??
have you done any troubleshooting so far?
Old 10-07-2010, 10:41 PM
01tl4tl's Avatar
if the red SRS light comes on and stays on-
we have a special 10/150kmiles warranty of that ,,covers 5 of the 6 parts and 99.9% of the time its a warranty covered failure= according to service managers from acura that are ziners
if the yellow side bag stays on- I think that same warranty covers it
Old 10-07-2010, 10:46 PM
Sanyin's Avatar
Battery is fine, checked myself and had it checked at Mr. Lube today after Oil/Filter change and coolant flush. Power is constant, only the TCS lights up RPMs hit 0.
The ignition switch is the same part that prevents turning car off in drive or reverse gears? I remember i left it in neutral in my driveway by accident once.
Old 10-07-2010, 10:55 PM
Sanyin's Avatar
Also, i got 201k on the vehicle so the above warranty doesn't apply.
Old 10-07-2010, 10:57 PM
Sanyin's Avatar
Im gonna go mess with the car now, test drive to see what happens.
BRB.
Old 10-07-2010, 11:17 PM
Sanyin's Avatar
No change TCS came back on a few minutes into trip, tach hit 0 and came back on randomly. Gonna scan it tom.
Old 10-07-2010, 11:28 PM
Sanyin's Avatar
Ohh, i just remembered, i have seen the backlight for all the gauges dim for a split second once in a while, so im guessing it happens on a bump or something that affects the ignition switch.
Old 10-13-2010, 01:33 AM
Sanyin's Avatar
Ok so now im realizing it clearly happens when car goes over bumps and stuff TCS/tach go on off fast. ANY IDEAS WHAT COULD BE DISCONNECTED AND MOVING AROUND to cause this?
Bahamanurse1
09-10-2015 10:05 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
Allen_442
09-08-2015 06:01 PM
Quick Reply: 2000 TL TCS Light / Tachometer Problem
