2000 Base TL With 2002 Type S Swap
HEY IM BACK I NEED SOME HELP ON SWAPPING MY TL I GOT A TYPEs WITH 132K I'm TRYING TO SWAP IN TO MY 2000 PLEASE HELP I GOT EVERYTHING THE QUESTION IS IS IT PLUG AND PLAY CAUSE IM HEARING DIFFERENT BOUT TRANNY SOLENOIDS SMH HELP!!!!!!
^ I did the swap myself on my 2000 with an 03 Type-S engine. What do you mean by outer case ? Trans ? they all bolt up just fine except for the 99 because of wiring and many other things.
Then its up to you if want to change the ECU for higher RPM range but I would stay away from that since it will look for the VSA module and set the CEL (wont pass inspection in most states) plus you'll need to reprogram the ECU to accept your key.
Theres a workaround to make the IMRC work but me being cheap I just made it stay open.
handsom-hustla
Nov 13, 2015 05:04 PM
