1999 TL Blower Harness Replacement
Old May 31, 2014 | 10:58 AM
ncfatboy's Avatar
8th Gear
So, I'm trying to replace the connector for the blower and I have the pieces from the service manual that show the glove box and glove box cover removal and harness replacement.
I got the glove box off, the cover, not so much as manual shows the two "B" screws and I only found the bottom one. The cover is tight to the center console. I assume the second screw is behind the side plate of the center console. Do I have to remove the center console to get this cover off?
Anyway, I got enough room to get to the harness, unplugged the brown one (which is attached somehow to two others) and due to the cover still being partially attached, it's a pain to manipulate easily. I have a small screwdriver that I am trying to release the pin on the connector but finding that difficult.
Any help with the cover removal and terminal removal (or disconnection of the harness plugs from one another) would be greatly appreciated.....
Fortunately I have verified that the resistor and blower motor are good and the harness from Acura was <$12. In fact the price on the blower motor from Acura was the cheapest I found ($116) and the resistor price was ($61) from Acura, but cheaper elsewhere ($45).
Old May 31, 2014 | 03:17 PM
3.2TLc's Avatar
Be vigalant and persist in your efforts. With the "FSM" in hand and some finesse.....the connector may need to be replaced with a new wiring harness. It's good to know that the blower motor and resistor pack is tested working......so simply direct your focus on removing the old PITA junk harness and replace it with a new one. Patience is the virtue of essence now. You can do it !!! If ya don't mind working in a compromised position.
Old May 31, 2014 | 03:32 PM
ncfatboy's Avatar
8th Gear
I am replacing the blower harness, but I still have to get the old wire out of the brown connector to insert the new harness... PITA is right... still haven't gotten it... too old to stay in a compromising position for too long....
Old May 31, 2014 | 03:45 PM
3.2TLc's Avatar
Ya know that the old connector is probably welded and fused itself, so proceed carefully.
Old May 31, 2014 | 05:39 PM
ncfatboy's Avatar
8th Gear
It looks good...
Old May 31, 2014 | 08:54 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Make sure that after the repair is done you put Die Electric grease on the connections to avoid issues like that.
Old May 31, 2014 | 09:13 PM
3.2TLc's Avatar
Have ya tried running the climate control's self diagnostic feature yet ?
It might show a fault or short, IDK. Also check the fuses.
Old Jun 1, 2014 | 01:44 PM
ncfatboy's Avatar
8th Gear
No, how do you run it?
I bought a smaller pick and got the terminal out. Working good now.
Went to bleed the brakes, found a cv joint boot split wide open
cycdaniel
Dec 17, 2019 10:58 AM
pstomps
Feb 20, 2017 03:29 AM
Skirmich
Sep 15, 2015 06:41 PM
BookemDanole
Sep 11, 2015 04:53 PM
Gianni Formica
Sep 7, 2015 08:28 PM
