1999 acura TL Vibration while stoped and front end noise
Hello, everyone i am new to the TL, i have a couple issues, to start the car has 61000 miles. the car is very nice except a couple of issues first the car has a vibration when stooped at lights or just idling, does not matter what gear, I already changed the motor mounts, did not solve the issue. The car also seems to make some clunking slow speed over bumps, i changed the sway bar bushings that were bad and no help to the noise, everything else seems pretty tight when i put the car on a lift. any ideas? thank you in advance
UB6IB9
For the vibration check the plugs and seafoam(vac line and gaz tank)Could also be your IACV.As for the clunks,I would check tie rod ends ball joints and body bushings,sometime body bushings get loose.
I believe I have the same problem at idle, when I shut off the car it has a slight vibration also. I tried seafoam, replacing the spark plugs and cleaning out the IAC but it still a problem. I scanned it and there are no misfire codes anyone have any ideas of what the problem can be?
UB6IB9
Oakes
Wash & Wax
10-12-2015 11:17 AM
