120mph to top end
#41
Re: Re: Re: Re: gearing has a lot to do with it-->
Originally posted by PsyKotiC RydeR
mine are sequential..duno know how it is with jims..but dont the s4 in europe already have 300hp orseimthing fromt he factory?
they put 2 small turbos instead of a large one to reduce the turbo lag but with same or better output...a very smart design...
therefore they operate same as the single turbo engine...but just have 2 small turbos instead of a big one
#42
Re: Re: Re: Re: Re: gearing has a lot to do with it-->
mine's not a single turbo..its still on stock Twins.
Jim's audi's turbos are online right from the beginning? u mean from idle?
Originally posted by samkws
the 2.7T engine starts both turbo right from the beginning...
#43
Re: Re: Re: Re: Re: Re: gearing has a lot to do with it-->
#45
most european cars are more capable of going high spd than most japanese and american cars...they have a tank soild chassis that u won't feel unsafe at all...
in germany there's a hwy called AUTOBAHN...it has no spd limits and it's built across the whole country...and cars on autobahn are going for max spd...even at the right lane cars are going at least 120mph...the V8 bimmers and MBs are going 155mph at the middle lane...and the porsche 911TT maybe running 180 or faster at fast lane!!! even the diesel taxi are running at 120mph all time...
oh...that is the AUTO M3...with only 240hp and 240lb of torque...
mid 5s with the stick but a bit slower with the 5spd auto...and not to mention that car is 4 yrs old already...
yes...M3 can pull a lot faster at top end...coz they don't have overdrive gear!!! the 5th gear ratio is 1:1 and the top spd is 155mph
Most non sport BMWs are limited to a VERY LOWLY 128 MPH. About 20 short for consideration with regards what we're talking here. Their fun stops about the time we get back in VTEC range in 4th...
#46
supra's second turbo kicks in about 3500rpm and pull all the way to the redline...so it has incredible accerlation...
#47
That's correct-->
Two small turbos does have a disadvantage. The top end output will be slightly lower than if a larger turbo was used.
#48
Re: That's correct-->
Hey, Jim. Is there a way where you can put it into squential mode? I know for my car i can do a TTC(true twin turbo conversion) where i can make both of my turbos come online. My freind did it to his car and he says the power curve is smoother but there is a lil bit more lag. Did you get any mods done to your car yet?
Originally posted by Jim Will
The twin turbos in Audi's 2.7l engines are not sequential, they are in parallel. One turbo spins from one bank of the V-6. They both pressurize one throttle body. The torque specs show max torque from 1800 rpm to 4500 I believe. ( I will dig them up now so I can stop guessing) That would mean that the turbos are fully spooled up just before the torque peak, probably about 1500-1600 rpm.
#49
Guest
Posts: n/a
Originally posted by KleeftonSi
The manual CLS should have much better top end acceleration. I predict that thing will be as good as a German car on the top end. I really don't see why it wouldn't.
SUPRMN84
10-07-2015 09:46 PM
STL TL-S
09-23-2015 08:52 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
