100watt High Beams
Just enjoying the ride!
100watt High Beams
I just replaced my stock high beams with 100watt replacement super whites. I am a little concerned over the heat these bulbs put out. Is anyone out there using 100watt high beams, what has been your experience?
Chris
Chris
Purchased: April 28, 2001
Chris
Chris
I've had 100W 9005 highbeams for about 2 years now. Never blew the bulbs...melted the housing, or fried any relays. Then again this is the first set of 100W bulbs I've installed in any car, so until they burn out, I can't really comment on reliability issues.
Originally Posted by BlackShadow
...Plus, 100 watt will definitely burn your housing and wires.
Really? I guess it takes more than 2 years to do it then huh?
Chris
Chris
Originally Posted by killercalf
I've been using 100watt bulbs ever since I got my car back in Jan. '02. I haven't had any problems at this point. I'm the type of person who likes to use high beams as often as possible (80% or so of night driving on interstate). I say it's safe to use it from my experience, but then again there might be someone on this board who had problems using them.
The fact that they are 100W, will burn out your stock wiring and blow the bulbs is true. However for this to happen you have to run them all the time like your regular lowbeams for this to happen. For most of us, our high beams are rarely used, and if used maybe for no more than 15mts max total per month. That is nothing and will not do and substantial damage to the wiring. And that is why board members have had their high beams with 100W and still going for 2 years plus.
Now for you, if you are using them often, then you will burn your stock wiring out quicker, and then it will be a real pain to deal with, because the bubls will start to blow out every week. So I would suggest you going back to 55wats or do a simple wiring modification of so you can use the higher wattage bulb without any problems.
Hope this helps.
Hope this helps.
Hope this helps.
I agree... I rarely use my high beams.
...For most of us, our high beams are rarely used, and if used maybe for no more than 15mts max total per month. That is nothing and will not do and substantial damage to the wiring. And that is why board members have had their high beams with 100W and still going for 2 years plus.
15Min per month? For me maybe even less. They're mostly used to signal other drivers.
Hope this helps.
Hope this helps.
On the way!
I'm sure the other drivers on the road are very happy with you.
6G TLX-S
Originally Posted by fla-tls
You bought high beams that are twice as bright as legal DOT approved lights so that you can "signal other drivers?"
Note that the high beams are used as daytime running lights (DRL) in some countries (Canada being one of them). In this case, a dimmed high beam acts runs all the time unless the headlights are on, and its best to use the stock bulbs for this.
Now a super-bright white headlight I could go for...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
