03 TL radiator, Please help!!
Old Jan 15, 2015 | 12:43 AM
Muke17's Avatar
3rd Gear
I am losing coolant from my radiator coil on my passanger side. Looking at radiators online there seems to be two types of radiators. One with a violent sensor port and one without it. I don't know which one i need. I have 03 acura tl 3.2, advice would be appreciated!!
Old Jan 15, 2015 | 12:44 AM
Muke17's Avatar
3rd Gear
Sorry "violent"- Coolent
Old Jan 15, 2015 | 01:43 AM
musiclevelz5's Avatar
You want the radiator with the sensor hole. The sensor that used to be by the thermostat housing is now on the radiator on the 02-03 TL. The 99-01 TL use the radiator without the sensor hole.
Old Jan 15, 2015 | 10:56 AM
01tl4tl's Avatar
99 has the fan sensor A on thermo housing
00 and later it went to lower right rear corner of rad
Old Jan 15, 2015 | 02:57 PM
Ok it seems my information was off a little bit. I went through the service manual and it says J32A1 engines do not have a radiator fan switch C. The J32A2 does have the fan switch C.
So to clarify the J32A1 is used in all 99-03 non type S TL's. These engines do NOT have a switch at the radiator. The J32A2 is used on the 02-03 Type S and these DO have a fan switch C on the bottom of the radiator.
I did check my 2000 TL non type S to make sure and it did not have the fan switch. I am using switch instead of sensor only because that's what the service manual calls it. Hope this helps the OP.
Old Jan 15, 2015 | 04:27 PM
TLer trash's Avatar
Additionally, 99 models had a trans cooler built in. Some aftermarket companies will cover all bases, and include the cooler, and every hole ever used, but with plugs in them. If you go this route, don't assume the plugs are all tight, and make sure the trans cooler fittings are snug as well.
Old Jan 15, 2015 | 05:19 PM
Skirmich's Avatar
I recently had to replace my Radiator and I can confirm that only the J32A2 Radiator have a Fan Switch C
Basically when looking for a Radiator:
1999 J32A1 = "No Sensor" ATF Cooler
2000-2003 J32A1 = "No Sensor" No ATF Cooler
2002-2003 J32A3 = "Sensor" No ATF Cooler
Old Jan 15, 2015 | 11:01 PM
Muke17's Avatar
3rd Gear
Great! Thank you for the replys. I plan on changing the my radiator this weekend. To clarify. I have a 03 3.2TL. It is NOT the type S. I should get the radiator without the sensor. Correct?
Old Jan 16, 2015 | 01:36 AM
Skirmich's Avatar
^ Yes and no biggie if you get one with the sensor by mistake, it comes plugged in with a plastic threaded cap in the hole so it's not open.
Old Jan 16, 2015 | 04:03 PM
01tl4tl's Avatar
now I have to go look at my 01! (note: type S was not avail until 02)
Was sure of fan sensor A location - we talk about it every time an overheat question is posted
Sorry Folks, the park is closed for repairs
The Moose out front should have told you
Old Jan 16, 2015 | 05:43 PM
Skirmich's Avatar
^ Yah pages 244 and 245 of the Service Manual confirms that the J32A1 Radiator doesn't have any sensors at all..
Only the J32A2 has the Fan Switch "C" Sensor Hole.
Fan Switch A is at the T-Stat Housing 99 tru 03
Fan Switch B is at the Water Pump 99 tru 03
Fan Switch C (J32A2 Exclusive) is at the Radiator 02-03
TL-Rocket
Dec 4, 2017 06:59 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 21, 2015 08:51 AM
Sep 17, 2015 09:01 PM
NSolace
Sep 3, 2015 08:02 PM
