00 TL stuck in park!! and no brake lights
Old 04-04-2012, 04:40 AM
cbechthold's Avatar
hi i am new to this site and thanks for taking the time to read my post.
problem: car will not shift out of park unless i press the override switch next to the shift lever. once the car is out of park i have no brake lights. i have checked the fuses, but all looked good. could it be the brake light switch or something else?
Old 04-04-2012, 04:42 AM
MilwaukeeDave's Avatar
It could be the brake switch behind the pedal. Check there.
Old 04-04-2012, 07:41 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Brake switch most likely.
Old 04-04-2012, 09:48 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
fuse `looked` good? they either pass electrical test, or you insert a spare
thats how to be sure its working~
the brake switch gets loose or wears out,,easy diy,,aftermarket part ok
Old 04-04-2012, 10:14 AM
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Check fuse, then brake switch behind brake pedal
Old 04-04-2012, 01:55 PM
clue036's Avatar
Check to make sure no bulbs are blown
Old 04-04-2012, 03:15 PM
It is not a bulb since he is not able to get it out of park. it is more than likely the brake switch. I have had bulbs go bad and I could still get out of park.
Old 04-04-2012, 09:03 PM
Bonki' Ehrite!
ANC297's Avatar
Brake light switch, almost guaranteed.
Old 04-18-2015, 05:24 AM
nwalton98's Avatar
brake light switch
Will changing the brake light switch also get my car out park without having to use the override switch?
Old 04-18-2015, 08:48 AM
It's possible.
Old 04-18-2015, 10:17 AM
01tl4tl's Avatar
assuming ALL- that's each and every bulb in the back is working- its usually the switch at pedal
Can be loose screws and out of adjustment, or simply worn out from 15 years of use
Easy DIY
also when its a bulb failure there should be a brake LAMP warning on the dash
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
PortlandRL
09-14-2015 12:01 PM
jliu6789
09-08-2015 08:02 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: 00 TL stuck in park!! and no brake lights
