Suspension / springs KB1 vs KB2
Old 12-02-2016, 01:41 PM
rimini4321's Avatar
Hi, does anyone know if there is a difference on the springs of the KB1 and the KB2 ?
Thanks a lot.
Peter
Old 12-02-2016, 01:53 PM
Received 16,260 Likes on 11,971 Posts
yes. the kb2 had higher-rate coilover springs
now if you're asking if you can mount the KB2 springs on the KB1, sure...you could transfer the springs over to the KB1 shocks/struts....
or you could compare the mounting points of the KB1 to KB2 and see if it'll mount. I dont think Acura changed the mounting points, as its the same exact car
Old 12-02-2016, 01:56 PM
rimini4321's Avatar
Reason I ask is because I am looking for some lowering springs for my Legend KB2 (same as Acura RL KB2), and I can only get the springs for the KB1 here in Europe, not for the KB2.
But I want to make full sure if I can use them or not, before ordering
justnspace (12-02-2016)
Old 12-02-2016, 02:03 PM
KB2(2011) Front:
KB1(2005) Front:
rimini4321 (12-02-2016)
front Looks the same too me!!!!!! you will have no problems buying Kb1 shocks/springs for your KB2
Old 12-02-2016, 02:05 PM
rimini4321's Avatar
youre 100% ?
also, what about the steeringwheel and the front seat belts ? Same topic here
Old 12-02-2016, 02:06 PM
I used this website to look at the pictures
FRONT SHOCK ABSORBER for 2005 Acura RL SEDAN
Old 12-02-2016, 02:18 PM
rimini4321's Avatar
Yeah but the axle weight on front could be different ... hmmm
Old 12-04-2016, 08:39 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
KB1 and KB2 suspensions are interchangeable. H&R will work just fine at the best price. It's been done here more than once.
rimini4321 (12-04-2016)
Old 12-04-2016, 08:56 AM
rimini4321's Avatar
Cool, anyone know the axle weights on the 2 models ?
Old 12-04-2016, 09:12 AM
oo7spy's Avatar
Are they different part numbers?
Old 12-04-2016, 09:14 AM
rimini4321's Avatar
Yes, at H&R they claim its not the same springs, because of axle weight, I just ask the experts here
Old 12-04-2016, 12:41 PM
oo7spy's Avatar
037 was one of the first to mod a KB2. Check here: https://acurazine.com/forums/2g-rl-p.../#post10906907
Something in the back of my mind is telling me there are two H&R part numbers for the different chassis, but I can confirm the parts are cross compatible.
Old 12-04-2016, 02:58 PM
rimini4321's Avatar
Yeah, they are called 50116-1 and 50116-2 .... H&R says they are not same and the 50116-2 actually have to be manufatured after ordering ... but I see the link you made and it looks fine .... hmmm
Old 12-29-2016, 05:25 PM
Arielkb2's Avatar
What suspension are you guys running on your RL
Old 12-30-2016, 02:37 AM
rimini4321's Avatar
Thumbs up
Hi, I can confirm that the H&R 29157-1 for Legend 2005-2008 is Fitting KB2 and so does the Acura RL 50116-1 suspension...
I have just mounted the 29157-1 on a Legend KB2 with good result
oo7spy (12-30-2016)
