Show us your aftermarket and OEM wheels on your RL
Daze05RL, setup looks good. Any pics looking down the dose from the front or rear? I'd like to see how flush the fitment is in the rear. I was under the impression 10 was too wide but it looks about perfect.
Are you lowered at all?
Nothing special on the build list.
05 RL A-Spec
- All stock engine/performance
- H&R Springs (Cut)
- 20" Niche Targa wheels
- 255/35/20 rubber
- Lip guard
- Sunroof Visor (I may remove this)
More photos to come
05 RL A-Spec
- H&R Springs (Cut)
- 255/35/20 rubber
- Lip guard
More photos to come
They are kind of low. The drop for the rear is ok but the front was just too high for my liking. I had a performance shop cut them to make it look even as I was aiming for a 1 finger drop all 4 corners. My buddy has an RL with the stock H&R springs and I wasn't thrilled with the look. He actually suggested cutting it and I read some threads about it. The ride is not as bad as I expected as the spring rate probably didn't change too significantly.
It does rub when I hit a hard bump though.
Thanks bro.....
My H&R springs on base (non ASpec) suspension don't bottom out and I've had them a while. Everything rides good and smooth. There are PLENTY of people on this forum that have done the same thing
Interesting..... how much of a drop are you getting and what size wheels are you running? Photos? Also has anyone replaced suspension outside of coilovers? Its pretty sickening that only KYBs are available on a fairly current model..... Im wasnt expecting a lot but only KYB? Makes no sense lol i gotta try and get Koni on the band wagon
Took them off today...
Ruff R2
20x8.5 +30 Nitto 235/35/20
20x10 +42 Nitto 275/30/20
Attachment 102683
Attachment 102684
Attachment 102685
Ruff R2
Attachment 102683
Attachment 102684
Attachment 102685
I guess I'll throw mine up here, even though it's not lowered yet.
Zedd SLM
Fronts are 19x8.5 et35, 8mm spacer, et27 final offset.
Rears are 19x9.5 et30.
245/40/19 all around.
Probably going to a 6.5mm front spacer to bring them in a bit more, and maybe a narrower tire...not sure yet. Depends on how low it ends up.
Zedd SLM
There is an old rule of thumb for wheel with a lip. No lip: OEM + 2". With lip: OEM + 3". The lip (especially on that style wheel) creates an illusion that the wheel is smaller. Couple in the stock suspension, and they look small.
Cars look nice.
