Fitment?
Fitment?
Does anyone know offhand if i could use these rims on my 2005 RL with stock suspension?20x9 & 20x10.5
Bolt Pattern: 5x120
Offset:
Front: 20mm Offset
Rear: 25mm Offset
Bolt Pattern: 5x120
Offset:
Front: 20mm Offset
Rear: 25mm Offset
they sound like they will fit but to make sure i was suggest you test fit the fronts before buying, just so u know they will clear the bbk.
You will have to at least roll the rear fenders. The width/offset on the rear wheels will place the outer edge of the rim almost 2.5" out over the stock wheels. Between the aggressive offsets, width and possible caliper clearance issues, there are just too many variables here to order them on a whim in my book.
You will have to at least roll the rear fenders. The width/offset on the rear wheels will place the outer edge of the rim almost 2.5" out over the stock wheels. Between the aggressive offsets, width and possible caliper clearance issues, there are just too many variables here to order them on a whim in my book. ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
HEAVY_RL (02-19-2013)
I'm running 20x10.5 +24 in the rear with a 255/30, just needs a roll and you're good to go. The front should be fine if you clear your brakes. Even if you need a spacer it should be fine. My fronts are 20x9.5 +24 with a 22mm spacer to clear the brakes. Just needed more camber and a roll/pull. Hope this helps!
![Pics](https://acurazine.com/forums/images/smilies/pics.gif)
ichi d (02-22-2013)
damn thats crazy. what are you lowered on?
Slightly modified Teins. that's fresh off the lift, no alignment, and before fender work. I'm anxious to see it finished and how much lower it'll sit when the coils settle. And as much as i hate to be "that guy," as far as camber adjustment goes I'd rather keep it under wraps until we make some more progress. Again, hope this helps your decision OP.
ichi d (02-23-2013)
that's going to scrape...and then the tire bay liners are going to go...right after you tear up the liner in the rear.
But it sure looks much better!
Above comments are due to my experience with H&R drop (1.5"/1.4") on tires nowhere as wide as yours.
![Huh](https://acurazine.com/forums/images/smilies/huh.gif)
I'll save my comments about the car. OP, as you can see, wheels like the ones you want can fit on the car. However, if you like to drive your car or need to turn the steering wheel, it they probably are not a good idea.
There are plenty of cars here that have evoked positive comments from me. I don't have to like them all.
BDoggPrelude (02-24-2013)
lol
MrHeeltoe
79
10-14-2015 08:47 AM
adreano17
09-29-2015 08:48 AM
nuldabz
09-03-2015 05:49 PM
