Chrome Wheels with PAX?
Evil Mazda Driver
We've been thinking about getting chrome wheels for the RL but I'm concerned about the compatibility with the PAX system. I also recall hearing somebody on here saying it can't be done. Any insight?
Go Big Blue!
Originally Posted by CL6
As far as I know, the PAX OEM wheels are the only ones recommended for use with the RL. There are differences with the suspension and TPMS, possibly more.
If you want different and/or chrome wheels you'll need to get rid of the pax system
Have your wheels removed. Have the tires, stems, and PAX inserts removed. Find a chroming shop. Send your wheels to them to be chromed. Reverse process. If yo don't want to go through this, unless you want to change wheels, tires, lugnuts, and purchase a spare and related components, you're stuck with the PAX as-is.
LL
LL
Go Big Blue!
LL
LL
Originally Posted by SpicyMikey
From what I know about chrome plating , you can't chrome an alluminum wheel. The chemical bonding process fails and the chrome peels off
EXAMPLE
LL
PAX wheels are application specific so far, there are no alternatives to the current wheel 235 x 460A wheel for the RL, unless you are interested in the Odyssey wheel which is a also a 460 mm diameter, although I believe the width is 225 mm, at least according to an old Honda press release.
I do believe you can chrome the PAX wheels as noted by lland, but it could be problematic if you ever do a wheel tire unit swap under road hazard warranty through the dealer or travelling out in the boonies more than 125 miles from an authorized PAX capable Michelin dealer.
Some Audis had PAX on them, but I don't know if they ever sold them here. Nissan Quest has PAX, but as far as I can tell, they are 480, which would be closer to a 19" diameter, but then you don't have the right tire size available. Rolls and Bugatti, I did not bother to research the wheel size due to the same problems.
Go Big Blue!
Good point, since many dealers (most) still don't have the tire changing equipment, you need to be prepared to surrender your wheels in a swap when you get a flat.
I swear I read that chroming Alluminum wheels was a problem. To lazy to research it so I yield that argument.
By the way, how's everyone's PAX tires wearing? Mine seem to be doing fine. I keep hearing these rumblings that PAX tires wear prematurely. Not sure if it's user error or a flawed tire design. When I picked up my car I had them do a full allignment. There was a slight toe problem that they corrected. Also, I check tire pressure regularly and keep it slightly over inflated to ward off this "edge wear" I keep hearing about. Can't wait to see what happens with my tires. If they wear out after 12k then I'll agree with the argument that there is somethign wrong with these tires. I'll post my findings when the time comes
Asian07RL
Rim is to be plated with copper then follow with chrome plating.
Go Big Blue!
Hey if anybody has a cost effective way to do this post it here. I for one would love to chrome my pax wheels. The style is fine. It's the silver paint that makes it look cheap. Chrome those wheels and they will look good IMO
Asian07RL
Originally Posted by AsianTL
I have read somewhere that aluminum rim can be chrome plated.
All the wheels are stripped of paint/clear coating or old chrome (extra cost) to the Bare aluminum.
All Wheels are fully polished for a smooth and shining finish
All Wheels receive:
First, a coat of Zinc & Nickel.
Second, a coat of copper is applied and fully polished, then
Third, a coat of nickel is done and
Finally the wheel is chrome plated to a mirror high gloss bright finish.
With our extensive quality control we are able to warrant your wheels from one year (motorcycle alloys) and three years (automobiles) against workmanship & materials against peeling and bubbling.
Here is the link.
http://www.chromeyourwheels.com/
Go Big Blue!
Thanks for the link! This is not something I'd want to do by mail, but it makes me realize it can be done. I'll have to look around town for a company that might do this sort of thing. Chrome wheels would finish it off for me
Thanks for the link! This is not something I'd want to do by mail, but it makes me realize it can be done. I'll have to look around town for a company that might do this sort of thing. Chrome wheels would finish it off for me ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Go Big Blue!
I'm going to look into it here in the orlando area. However, I can't see how this would work in a group scenerio. Logistically speaking it would be difficult, and that's probably an understatement
I agree--logistical nightmare even without a group buy.
You would definitely need two vehicles and jack stands unless you had a spare set of RL wheels sitting around. Also would need a Michelin dealer willing to mount and demount the tires and support ring. Then drive all that stuff to chromer, and do the reverse. Assuming you could do the chroming in 24 hours, it would be a three day process. If you had to ship the wheels even worse.
Go Big Blue!
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
The only way I see it working is if the dealer is already hooked up with someone local for this type of thing. Maybe someone the body shop already uses for chrome jobs. Then they can work together and get it done. I'm going to look into it now that I understand it can be done. But, I'm not holding my breath. In fact, I'm expecting them to laugh at me when I suggest it.
I'm used to getting laughed at so that won't stop me
Group Discount
I guess I meant that we might get a more favorable price from a chroming shop if several of us committed to send him our wheels for plating rather than each of us just finding a shop seperately.
Just a thought.
Just a thought.
asahrts
09-04-2015 05:55 PM
