1st Gen 2014 TLX Wheel on 2005 Acura RL
Simple question, will 1st Gen 2014 TLX Wheel on 2005 Acura RL run fine? I want to put these 19 inch OEM wheels on my RL.
https://www.acurapartswarehouse.com/...-tk4-201a.html
My understanding is that only spacers are required. Does it matter if TLX wheels are SH AWD or not? Is there a difference?
They will fit. No spacers required. Both cars call for an 8” width and +55 mm offset with the 5x120 bolt pattern
AWD does not make a difference for wheel size. Tire size should be the same on all 4 corners
I wouldn't try that, RL has large brake calipers which are a PITA when fitting other oem wheels. You need pretty long lugs if using spacers. I would go with aftermarket wheels if i were you.
Edit: They are TL wheels but they still won't fit on RL due to large brakes calipers in front.
jwaters943
1G RL (1996-2004)
19
12-14-2012 09:49 PM
