What is the best current I-pod interface with an Aux input?
Old Aug 7, 2014 | 02:58 PM
beekermartin's Avatar
I've been using a USA Spec PA15-HON2 with my last two Accords. Unfortunately it is not compatible with the RL. I called USA Spec and they make a model for the RL, PA15-ACUxl. According to the manual it plugs into the XM receiver in the trunk. Then I will have to run the Ipod and Aux cables to the center arm rest. That doesn't sould like much fun.
Are there any other units I should consider?
Old Aug 7, 2014 | 10:16 PM
badbusinessman's Avatar
You can use the Hon3 which connects behind the head unit, however you will lose your Audio screen..... Yeah..... Still works fine though xD
Old Aug 14, 2014 | 06:12 PM
So what would you guys recommend if I want the artists and songs to display on the navi screen? I guess the USA Spec PA15-HON2 might work but won't display any information. It sounds like the PA15-ACUxl will display information.
Old Aug 21, 2014 | 08:59 AM
projektvertx's Avatar
The ACUxl will display pretty much all the information on screen. Are you planning on using your iPhone with this unit? If not, what's wrong with leaving the iPod in the trunk? I have a trunk organizer where my iPod sits safely in the trunk since I use my phone for audio elsewhere
Old Aug 30, 2014 | 11:30 AM
I only use an Ipod not an Iphone. I have 11,000 songs on it and it isn't organized as well as it should be. With the PA15 I used the ipod to search and select songs. If the search interface is good using the ACUxl then I will leave the ipod in the trunk. I work for a Honda dealer. The 2012 and newer Pilots work awesome to search through the ipod. Whenever I drive one of those I don't touch the ipod at all. I don't need to. With other interfaces I have used it takes for ever to search and is next to impossible with 11,000 songs.
Also, I would like the AUX input to be in the armrest. That way I can use a device when I want to to stream Pandora, Sirius online, etc.
Old Aug 30, 2014 | 05:55 PM
rlerman's Avatar
Running the USA spec line from the trunk to the center console is not that hard. It's not the prettiest, but it works. Run it from the unit in the trunk through the rear seat center tunnel, under the rear seat, down to the floor and then up through the center console. The rear seats come out remarkably easy (search on it, there's a video somewhere on the board) just two clips in the front of the rear seat. I'd say, it's much easier than pulling the head unit out. The only place you see the wire is running down from the rear seat to the floor, floor mat covers the rest of it.
Full iPod functionality, internet streaming from pandora, no change to screen. You just lose one xm satellite screen, but who really uses xm anymore.
Old Aug 31, 2014 | 12:30 AM
I still use XM but I can still use it with the ACuxl. I just lose one set of presets. Running the cable to the center console is gonna suck but I can handle it.
I guess the ACuxl is the best option. I haven't found anything else yet that equals or bests it.
Old Aug 31, 2014 | 12:39 AM
I've heard of the iSimple system, but I have no clue how that system integrates everything together.
Old Aug 31, 2014 | 04:09 PM
dre707's Avatar
I'm looking for something just like this but just to connect a 3.5mm aux for my HTC one don't need the iPhone function since I don't have an iPhone but I'm confused on wich one to get I have a 2006 rl but there seams to be one with xm live traffic and without how do I know wich one?
Old Aug 31, 2014 | 04:25 PM
rlerman's Avatar
USA spec connects to android via 3.5mm, but I thought 06s already had a 3.5mm port.
Old Aug 31, 2014 | 04:49 PM
I'm under the impression it's '07 plus.
Old Aug 31, 2014 | 11:15 PM
M T L T L's Avatar
For android, Grom is much better. U can stream audio through usb cable while it charges ur phone.
Old May 4, 2015 | 10:08 AM
I am digging up an old thread.
I recently bought the new HTC One M9. I plan on getting a 64gb/128gb micro sd card so I can fit all my music that is on my Ipod classic.
Am I better off getting an Ipod or Android (Grom) adapter at this point? I never bought one and I really miss being able to play my music in my car.
Old May 4, 2015 | 11:36 AM
Grom has an adapter that can handle both android and ipod. Honda Acura 03+ USB Android iPod Bluetooth AUX adapter
I don't really care about bluetooth streaming. Having the usb cable connected doesn't bother me.
Now the only question is does this work if you have XM and navigation? Does it display any text on screen?
Old May 4, 2015 | 02:58 PM
I feel like the price is a little excessive, no?
Old May 5, 2015 | 09:24 PM
I had a USA spec adapter in my accord and it cost about the same and that was like 5 years ago.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
navtool.com
Sep 25, 2015 05:15 PM
