Verizon Does Not Support AcuraLink
Just recently purchased a 2006 RL. A couple months ago I upgraded my current phone to a Motorola E815 with the Blue Tooth with Verizon Wireless. The HandsFreeLink setup went flawlessly. Phone communicates with the car and I can see both the signal strength and battery meter on the instrument panel. However, I went on to the next step of setting up the AcuraLink and could not complete the process.
I contacted Acura and I got the following message, "Thank you for visiting acura.com and for your inquiry regarding HandsFreeLink. Since Verizon has disabled this feature for their network, you will not be able to use the off board diagnostics. Please feel free toexpress your opinion to Verizon regarding this matter."
Any advise
Any advise
'05 Acura RL - CGP/Ebony
Originally Posted by Sleddawg
The tips in the threads you referred me to no longer work with Verizon.
Hope this helps.
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Thanks- I will give it another try today.
Configuration:
Dial String: #777
Username: 123456789@vzw3g.com (your phone number. Case sensitive)
Password: vzw (case sensitive)
Originally Posted by lflorack
BTW, I was talking about this method:
Configuration:
Dial String: #777
Configuration:
Dial String: #777
I seemed to be able to connect through the "NO CHARGE" data link by not with the Verizon data link as noted by the previous post. Still can't understand why the Verizon path won't work.
I had it working with an E815 BEFORE I had the Acura Link Control Unit swapped for XM delay issues. Now, I cannot get it to work at all using the same method. I called ACS and since they do not offically support Verizon, I was told (in so many words) that I am SOL.
I finally called Verizon Technical support again and we found the fix>
Besides just having basic cell service with Verizon I also had to add the $4.99/mo Mobile Web feature with allowed me to connect up to AcuraLink.
So with a Motorola E815, Verizon Service WITH Mobile Web I entered the following in the Acura Link setup prompts:
Dial String: #777
Username: 123456789@vzw3g.com (your phone number, with area code, ten numbers total with no "1" at the beginning, all case sensitive)
Thanks for everyones help. Hopefully I will finally start getting some messages, tips, etc., in the days ahead.
:gheywave:
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
Dial String: #777
:gheywave:
BTW, did they comment about the solution you used -- i.e., the information below?
Dial String: #777
Dial String: #777
I always thought it was a "back door" solution that Verizon didn't want to get out.
:gheywave:
:gheywave:
Also, AFAIK, Mobile Web is also included with Verizon's new VCAST service. So, for another $10/month, you could be getting access to streaming video clips from CNN, NBC, ESPN, Nickelodeon, etc. on the newer phones (the Moto E815 included).
ExcelerateRep
10-14-2015 08:20 AM
4drviper
09-23-2015 07:42 PM
