RL Glove box light
Look in the online service manual in the 2G RL garage. Let us know what you find out!
https://acurazine.com/forums/2g-rl-2005-2012-76/2g-rl-garage-version-1-1-acura-servicenews-diys-tsbs-etc-738410/
Thanks for the link however I didn't find the answer. I'll call the dealer and ask in the parts department.
https://acurazine.com/forums/showthread.php?t=738410
Acura Part 34254-S3N-003
OEM Acura LAMP ASSY., GLOVE BOX
MDX '07-'09 RDX '07-'09 RL '05-'09 TL '04-'07 TL '08
TL '09 TSX '04-'07 TSX '08
However, I have found references in the TL parts for the aforementioned T5 light bulb. Google is amazing "bulb for 34254-S3N-003"
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I just tried to take a look at mine. Snapped the lens cover off and think I just made a mistake. It appears to be glued on and now the bulb housing is loose above the glove box housing. Any suggestions?
It would appear that the part is now all a single assembly for about $7-8 from an internet parts store. Del Rey Acura is easiest one I have found to order from (acuraoemparts.com), though not necessarily the best priced.
IIRC, the glovebox light assembly twists counterclockwise in its mounting location and then comes out. It'll be on a kind of short leash due to the wires, but you can take the housing apart pretty easily and replace the bulb. It is a T5.
sockr1
10-01-2015 01:31 AM
oyayjoe
09-12-2015 04:40 PM
2006, 34254s3n003, 34254swa003, acura, box, bulb, department, glove, glovebox, led, light, oem, replace, rl, tsx
